ODB2 not communicating
Old Jun 18, 2020 | 08:30 AM
Richierich73's Avatar
Default ODB2 not communicating
Hi, I have a problem with the ODB2 port not communicating, both at a local garage and at home. I found a previous thread that suggested checking the power on pins 6 and 16, and checking fuses. pin 6 showed 4.5v, but pin 16 shows zero. The thread showed fuses 80 and 72 for the ODB2 port, but this was for a 2001-2003 model, what are the equivalent fuses for a 2005 model 2.0 Diesel? Does anyone have any further suggestions?
Thanks,
Richard
Old Jun 18, 2020 | 09:59 AM
JagV8's Avatar
16 should be batt+ but did you put ignition on fully?
You can look up the pins on the net BTW.
Old Jun 18, 2020 | 10:12 AM
Hi, thanks for answering.
I had the engine running when I checked the voltages.
I found F7, F25 and F32 are for on-board diagnostics, checked these, but they were fine.
Regards,
Richard
Old Jun 18, 2020 | 12:48 PM
JagV8's Avatar
Well, you know you've a fault on at least one pin.
Xag
Jul 13, 2022 02:42 PM
kingnero
May 4, 2020 03:48 AM
Lawrence Galea
Jul 21, 2018 06:45 AM
BruceL6901
Jul 3, 2014 06:52 PM
jagpro69
Sep 10, 2010 09:36 PM
