oil change 03 x type
Old Jan 31, 2015 | 09:52 PM
manuelm768's Avatar
Default oil change 03 x type
Hey guys I have a 03 x type 2.5 auto.. is it possible to do your oil change yourself? I tried and the plug bolt is extremely difficult to unbolt. Im using a 13mm socket and no luck. Im I doing something wrong? Thanks in advance
Old Jan 31, 2015 | 10:26 PM
Bud Tender's Avatar
https://www.youtube.com/watch?v=B-O47gv6ig0
Old Feb 1, 2015 | 06:52 AM
Thermo's Avatar
Veteran: Navy
manuel, doing the oil change on this car is pretty easy. From the sounds of things, someone over tightened the plug the last time thinking it was the source of an oil leak. Sounding like you are going to need to get a slightly bigger breaker bar to get things loose. I would also say to make sure that you are turning it in the correct direction. Being under the car, you can sometimes get turned around and take things the wrong direction.
Old Feb 5, 2015 | 05:01 AM
manuelm768's Avatar
Thanks you guys just got it done!!
FabCat
Canada
Aug 20, 2023 10:11 AM
JaguarXKR
Sep 6, 2015 11:47 AM
niner nellie
Sep 1, 2015 10:53 PM
DeaconHull
Aug 31, 2015 10:09 PM
TC Johnson
Aug 29, 2015 08:55 PM
