Oil Pump
Old Oct 9, 2011 | 12:02 PM
Directvmandan's Avatar
Jagmandan
Exclamation Oil Pump
I Love my 2002 Black Cat. But i have a major problem. She has 144700 miles on her and I have had her for a month and and half, I only got to drive her for three weeks. Cruising on the interstate around 88mph, she started making a sound like she was falling apart, engine lite was on and she started slowing down. I got off of the interstate and she quit on me. When the clanking screeching noise started the oil light started going on and off.There was no oil under the car and no smoke from the engine. The temp gage showed normal. The previous owner used synthetic oil. The manual says not to use this type of oil. The dipstick showed low oil, so I added 2 quarts of oil. This got the car started back up and I got it home. It sat at home for 2 whole days. Depressed because I figured I bought a .lemon. So I drain all of the oil and exactly what it calls for, still clattering. I wash it every day cause its the only one in the county, Looks good sitting in the driveway. lol Anyway I started it last night when we were cooking out and the sound now comes from the top instead of the bottom. I am hoping I have a bad oil pump. Any Ideals would be greatly appreciated. I am open foe any suggestions. Dan the Jag man
Old Oct 9, 2011 | 12:25 PM
Jagmandan
Does anyone know if can change an oil pump without pulling the engine?
Old Oct 9, 2011 | 02:03 PM
Dan I've moved your posts from the new member area, hopefully you'll get some advice here.
Old Oct 9, 2011 | 05:33 PM
motorcarman's Avatar
You need to do a search for "replace oil pan gasket" or "drill a hole in transfer case to access oil pan bolt".
The pan can be removed without pulling the engine but I think the DAMAGE IS DONE!!!!!!!!!!!
bob gauff
Old Oct 10, 2011 | 05:26 AM
Jagmandan
Default Directvmandan 2002 jaguar x-type
I'm curious what does the oil pan gasket or drilling a hole have to do with the engine making the noise?
Old Oct 10, 2011 | 05:42 AM
Jagmandan
Thank you for answering my question. It sounds like a job huh?
Old Oct 10, 2011 | 08:12 AM
You asked if you could change the pump without removing the engine.
So I posted how to remove the oil pan without removing the engine.
bob gauff
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
Jandreu
Jun 30, 2022 03:10 PM
ccfulton
Sep 20, 2015 05:15 PM
