One touch up power windows
Old May 16, 2010 | 04:34 PM
DZtt's Avatar
Question One touch up power windows
So I don't know if this is a coincidence or what, but I was changing my fuel filter today and disconnected the battery to do the job. I now noticed that when I pull back on all the power window buttons for one touch up they no longer go up all the way. They act just like normal non-one touch power windows. The one touch down works fine. Any ideas on this? Is there a fuse specifically for windows up? Did disconnecting the battery clear this feature? Any help greatly appreciated.
Old May 16, 2010 | 05:00 PM
jn_lego's Avatar
when the window is up, leave the button pushed in and put the window the entire way down. then keep the button pushed and put the window the entire way up. leave the button held in for about 3-4 seconds after it is up (maybe longer). the auto-up feature now works.
Old May 16, 2010 | 05:35 PM
DZtt's Avatar
Worked perfectly thanks!
Old May 14, 2011 | 06:41 PM
learjetjag's Avatar
Holy Crap I had the same problem and was pulling fuses all day, Thanks, I really like this forum!!
Old Sep 22, 2011 | 12:05 AM
saintmute's Avatar
And here we are in Sept 2011 and this post is still helping people. Thanks again!
I do want to add however, for those of you "googling" this information...
...that you have to do this for each window. Also I'm not sure if it's a fluke but when I did it, once the window was completely down I had to hold it for about 4 seconds before raising the window completely and then holding it for 4 seconds. It didn't work for me if after lowering the window I immediately raised it and then held it fully raised for 8 seconds. *shrug* The important thing is that it was easy to figure out with these instructions and now my windows work properly again! Yay!!
Old Sep 22, 2011 | 04:15 AM
Cadillac's Avatar
Thanks guys for your feedbacks , it is nice to see these topics help others
Old Oct 3, 2013 | 01:09 PM
bfuentes's Avatar
Well in 2013 your post has helped someone out again. thanks this helped me so much!
Old Oct 10, 2013 | 03:07 PM
WayneCountyBill's Avatar
Default Works Like a Charm!
Yes. When you disconnect the battery most everything in the vehicle will need to be re-set (moonroof, windows, radio station settions and bass/trebble).
Old Oct 12, 2013 | 06:30 AM
Pacobell's Avatar
I found that within a day or two of disconnecting the battery without hooking up an auxiliary to the power port first, the systems "'re-learn" the functional programming like the auto lifts on their own during use but the power seat, radio settings and clock need manual reprogramming.
Old Oct 14, 2013 | 05:45 PM
lancervi50's Avatar
Fantastic thread. I was pulling fuses out myself after I had a new battery installed and stood there like an idiot while pressing my remote for the windows to automatically go up...when they didn't. Thanks guys
Old Nov 3, 2013 | 05:25 PM
jaxam1's Avatar
And one more person who was helped today. Great forum. Got a question? Someone has an answer.
Old Mar 30, 2014 | 08:55 PM
theresetodd's Avatar
I was racking my brain trying to figure out why my one touch UP position wasn't working and thanks to this post, 2 seconds later, my windows work great now. If it wasn't for this forum, I would be lost. Thanks again
Old Apr 1, 2014 | 08:01 PM
Rhalsall's Avatar
I had a very similar issue...per the owner's manual, pull back on each of the window buttons (one at a time) for 1 second and it will reset. All of mine except the rear right is working normally. Still don't know what to make of the that. Hope this helps...cheers
Old Jun 22, 2014 | 02:01 AM
scotty1511's Avatar
Thanks for the info, will try tonight.
Old Jul 14, 2014 | 02:42 AM
Tiger88's Avatar
I'm also having a problem with the right rear window. All of the other windows work fine.
If I operate the right rear window from the right rear door switch it works as it should. But if I use the control on the drivers door the auto up and auto down don't work for the right rear only.
I've tried the calibration procedure from both locations.
Old Jul 14, 2014 | 09:22 AM
Thermo's Avatar
Veteran: Navy
For those with issues on the right windows, odds are, you problem lies in the driver's door switches. If they become loose, the switch does function like it should and results in the window not getting properly configured. If you pull off the driver's door panel and then get the switch in the proper position, all will work better. Kinda like you can get it to work a bit better by lifting and pulling the switch sideways towards the outside (as I recall) as you lift it to make it go up with the 1 touch feature.
Old Sep 1, 2015 | 11:08 AM
JMRellama's Avatar
This thread helped o e more person today. So much that I am now a member of ths forum. Thanks for the one touch reset help!
Old Jan 26, 2016 | 04:44 AM
thedebs53's Avatar
Many many thanks DZtt, saves me putting a post on here to ask! Top man
Old Nov 23, 2016 | 11:17 AM
LABronzeJames's Avatar
Default Listen for the click when teaching window limits
I tried this, and when I held the button up or down after the window stopped, I heard a little relay inside each door make a clicking sound.
I suspect that's when you've 're-taught' your window drive what the travel limits are, like that little beep you hear when you teach the seats a new memory position.
Old Dec 20, 2018 | 05:40 AM
Gagsy's Avatar
Default New alternator
Fantastic, just read this and it works, amazing!! Thank you so much
I've just had a new alternator fitted and wanted to take my beautiful xj6 out for a drive and discovered only the drivers window auto closes so I tried this and hey presto !
Thank you again!!!
