One touch windows - Reset
When you disconnect the battery, you need to reset all the one touch features.
The way to do this is simple, basically roll the window down and keep the switch pressed after the window is all the way down for a couple seconds. Repeat when you roll the window back up, and voila the one touch works again =) You need to do this for all the windows, and it only works from the drivers door switch.
Same applies for the sunroof.
Basically it lets you choose which windows you want to have one touch...
Hope this clears things up,
George
George
