is this the Outlet pipe connection?
Old Mar 9, 2014 | 03:24 PM
summerwind4's Avatar
Default is this the Outlet pipe connection?
searching but found nothing so far..............the pipe has 3 hoses connecting to it.....upper rad. hose, coolant tank and what looks to be a heater hose.....
the pipe tree is in great shape, but found this "what i hope to be" the last leaking issue to deal with as i have replaced all the cooling systen components.
i would like to know if the rubber seal is an "o-ring" or another special ring, and where i can find it.
thx
-mike
Attached Thumbnails is this the Outlet pipe connection?-img_1043.jpg   is this the Outlet pipe connection?-img_1044.jpg
Old Mar 10, 2014 | 07:09 PM
thx anyways.
i found the part and got it ordered.,
it is a peculiar joint that will not show itself while the car is running.
Old Apr 17, 2014 | 06:56 PM
tford's Avatar
hey bro what's the name of that part and where did u find it? i have the same problem..
Old Apr 18, 2014 | 08:14 PM
hi tford,
sorry not to answer til now.......been gone all week.
i bought the O-ring at the jag dealer here in town......3 bucks.
part number C2S22458
it is online too, but who wants to pay for shipping.......
C2S22458 Jaguar O-RING
Old Nov 12, 2016 | 04:41 PM
dwclapp's Avatar
I hope these pictures help the next person.......
Attached Thumbnails is this the Outlet pipe connection?-jaguar-coolant-leak-1.jpg   is this the Outlet pipe connection?-jaguar-coolant-leak-3.jpg   is this the Outlet pipe connection?-jaguar-coolant-leak-4.jpg   is this the Outlet pipe connection?-jaguar-coolant-leak-5.jpg   is this the Outlet pipe connection?-jaguar-coolant-leak-6.jpg
is this the Outlet pipe connection?-jaguar-coolant-leak-7.jpg   is this the Outlet pipe connection?-jaguar-coolant-leak10.jpg
Old Nov 12, 2016 | 05:14 PM
swingwing's Avatar
dwclapp, could this o-ring cause an intermittent coolant leak down that end of the engine that drips onto the Bank 2 exhaust pipe? I'm chasing slight coolant loss and recently noticed a small amount on garage floor below that section of the engine. I took off the right front wheel and access plate for serpentine belt tensioner, then ran engine. Couldn't see anything leaking, but this hose/pipe junction is suspect. Thanks for the pictures.
Old Nov 13, 2016 | 07:58 AM
dwclapp's Avatar
swing: This coolant leak is difficult to find, but easy to fix. So the "lazy man's" remedy is replace this suspect o-ring, hope your leak stops, and if it doesn't, replace the next easiest, suspect part.
The o-ring I replaced cost only $2 at a hardware store, or $7 for the official Jaguar part C2S22458 on eBay, and takes only ~30 minutes to replace if you're cautious the first time, ~10 minutes with experience.
So my 2 cents: replace this suspect o-ring, declare victory if the leak stops, or keep searching if the leak continues. The coolant splitter housing (see pictures) has 2 more o-rings you might check, but I didn't replace those because other forum members point to problems with the suspect o-ring, and the leak stopped when I replaced it.
Attached Thumbnails is this the Outlet pipe connection?-jaguar-coolant-leak11.png   is this the Outlet pipe connection?-jaguar-coolant-leak12.png
Old Nov 13, 2016 | 08:26 AM
swingwing's Avatar
Thank you, those pictures and advice much appreciated. Speaking of pictures, I've not seen the .png suffix before. How is that different from .jpg? Newer camera perhaps?
Old Nov 13, 2016 | 08:38 AM
dwclapp's Avatar
swing: The jpg's are from my iPhone while working on my 2002 X-Type.
The png's are screen grabs from this eBay post: 2007 Jaguar Xtype 3.0L Coolant Pipe Tube Sensor With Tee OEM (Part# 1X4E-8548EA) | eBay
Both picture formats are very common.
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
xjrjag
Oct 24, 2024 03:09 PM
Tim Goz
Sep 17, 2015 09:11 AM
1100me
Sep 7, 2015 06:26 AM
