P0193 code plus amber engine light
Old Apr 29, 2019 | 07:53 PM
aznewsh's Avatar
Default P0193 code plus amber engine light
I have a P0193 code plus amber engine light, prior to this I was starting to see occasional hesitation on acceleration.
Research seems to indicate the most likely cause to be faulty Fuel Rail Pressure Sensor although it could be electrical related, I decided I would first try changing it out before taking on electrical diagnostics.
Here are the codes I got:
So then the fun started, I located the fuel rail pressure sensor in the car and it quickly became apparent that it is not easy to access:
I moved a large hose out of the way and then tried to remove the next one but don't know how to release the clamp without damaging (see below circled in yellow)
Also am I in for any surprises or do you have helpful hints if I get past this?
Thank you for your time
Old Apr 30, 2019 | 12:01 AM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...lation-199689/
Old Apr 30, 2019 | 09:03 AM
aznewsh's Avatar
Thanks will try it this evening and see what else I find under that whilst trying to get to the fuel rail pressure sensor
Old Apr 30, 2019 | 08:54 PM
aznewsh's Avatar
Gave it another try without success though I didn't try too hard because the more I look the more it looks like I need to remove a bunch of stuff to get to it. Is there some kind of workshop manual that tells you what steps are required or has anybody done this before that would be willing to share steps?
Old Apr 30, 2019 | 08:56 PM
Main page in the "stickies" is a downloadable workshop manual.
Old Apr 30, 2019 | 10:18 PM
aznewsh's Avatar
OK thanks, that confirmed what I suspected, I will need to remove the throttle body to get to it, rather annoying since I changed that a couple of years ago, oh well might be easier this time!
Old May 6, 2019 | 05:50 PM
aznewsh's Avatar
So quick update, I replaced the Fuel Rail Pressure Sensor, then cleared the codes and so far everything seems good, the codes have not returned. It is not easy to get to even after removing the throttle body but after after moving a few other things it's just possible.
This is the one I replaced it with if anybody needs to do this in future:
Standard Motor Products FPS17 Fuel Pressure Sensor Standard Motor Products FPS17 Fuel Pressure Sensor
Hope this helps somebody in the future.
dag82
Oct 28, 2019 02:37 PM
Harry Peter Rose
Feb 23, 2019 10:05 PM
mhannaoui
Nov 18, 2018 11:16 PM
Wahooesprit
Nov 2, 2015 01:53 PM
the xkr man
Mar 17, 2013 07:04 PM
