P0340 code
Old Oct 28, 2012 | 07:24 PM
Wahooesprit's Avatar
Default P0340 code
Hello
Just cleared a check engine light with my scanner and got the above code so I was wondering if there are one or two downstream o2 sensors and also if the Bosch ones on rock auto are good replacements. I was going to replace them first since the age and mileage but my next question is if the cats are indeed bad can I just put some universal hi flow cats on or is it a Jaguar only cat.
Old Oct 31, 2012 | 06:07 PM
Got my jagbits order--upper/lower gaskets, imt gaskets, new pcv valve and updated hose and my iridium plugs everything went in without a hitch in a couple hours cleared the codes and the car runs great--even had to replace the three bolts on the back of the manifold but was easy to take off
Old Nov 5, 2012 | 05:47 PM
Ok, code 430 came back so I put a set of Denso O2 sensors (downstream) on and this was the fix--the rear O2 sensor was some kind of bitch(even up on my rotary lift), the front was was easy.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
