P0443 code
Old Mar 12, 2015 | 07:27 AM
springer's Avatar
Default P0443 code
My 06 x-type is giving a code of P0443. I have one of those bode traders that links to my cell phone and don't really know if it's that good or not. The code states that is the evap solenoid. can anyone tell me if this is true and if so can anyone tell me where the solenoid is located thanks in advance.
Old Mar 12, 2015 | 09:32 PM
Thermo's Avatar
Veteran: Navy
springer, I was having issues with my purge valve. I found that if I removed it and cleaned it out with some carb cleaner, all was better. In your case, the solenoid that you are after is on top of the gas tank near the rear diff. So, to get access will probably require dropping the tank atleast partially to give yourself some more room.
Old Jan 4, 2017 | 10:42 AM
springer's Avatar
you you wouldn't happen to have the part number for that valve would you isn't this the same valve that they use on a Ford F-150 also
Old Jan 4, 2017 | 02:00 PM
Thermo's Avatar
Veteran: Navy
springer, the valve in question is called a "purge valve". It is Jaguar part number C2G2403. As for the valve being interchangeable with a Ford F-150, I would be very doubtful it would be.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
