P1338 and P1699 codes HELP
Old Jun 24, 2010 | 03:06 PM
number1stun's Avatar
Default P1338 and P1699 codes HELP
What do P1338 and p1699 mean ..got these codes on my 2004 x type 3.0
Old Jun 24, 2010 | 05:36 PM
Thermo's Avatar
Veteran: Navy
stun, I know you are not going to like what I am about to tell you, but this is how things are looking.
P1338 - Fuel Pump feedback circuit low/high voltage. This is indicating that your fuel pump is either getting too much voltage or too little voltage as is sensed by the fuel pump control module. Now, this can be caused by either bad wires between the ECM and the fuel pump control module or a bad ECM.
P1699 - CAN ECM/ACCM network malfunction. What this is saying is essentially that the computer for your engine can not talk to the rest of the car. This can be caused by a bad data bus or you have a problem with the ECM.
The only thing that is really in common with the two problems is the ECM. Now, if I remember right, you are also fighting an issue with the cooling fans for the engine not working properly and you were getting a low signal from the ECM. Tossing these 3 things together, I am pretty sure that your ECM is starting to take a dive and it is time to get a new ECM. LIke I said, I don't think you are going to like what I have to say. But, that is what things are looking like.
Old Jun 25, 2010 | 05:56 AM
Thanks thermo water pump has been change , I didn't have a prob with the cooling fans and the car never over heated I would add coolant everytime I drove it and I'm in big trouble if it's the ECM I heard they cost like 1200 and I live pay check to pay check what should I check first please help me I'm desperate
Old Jun 25, 2010 | 08:23 AM
motorcarman's Avatar
DTC guide for your car (actually all gasoline models 2003MY>)
bob gauff
File Type: pdf
Old Jul 3, 2013 | 01:21 AM
Candy's Kitty's Avatar
I'm getting p1338, P0191,P1000, B1582, B1260, And b1647. I pulled into the gas station the other day car running fine. Filled up half way. Then started and spuddered out like it out of fuel. Now it won't start at all unless it running on carb cleaner. All fuses are good and relay is good. I replaced the fuel filter and the fuel pump (with a used one 6month warranty from a running car) I'm not getting fuel to the rail or the filter. Ideas anyone pleeees!!!
Old Jul 3, 2013 | 07:55 AM
Thermo's Avatar
Veteran: Navy
Candy, in your case, the problem may lie in the fuel pump module. Unfortunatley, to access the module, you have to drop the fuel tank again. The other check that I would do is a hand over hand of the wiring running between the ECM and the fuel pump module. It is possible that through driving and the recent work, the wiring bundle has gotten damaged and what is happening is the signals that are going between the ECM and the fuel pump module are getting shorted out and therefore the fuel pump module does not know to turn on.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
