Passenger AC vent grill removal
Old May 8, 2024 | 08:49 PM
RBaczek's Avatar
Default Passenger AC vent grill removal
I’m looking for instructions on the removal and installation of the A/C vent on the passenger (LHD). The adjustment wheel no longer works and the vent is closed.
I’ve looked at X-type manuals and they don’t address that. I’ve also seen videos to remove the center grill, but not the passenger side grill.
I have a 2002 X-type, left hand drive, 3.0 Auto
Old May 9, 2024 | 01:19 AM
Dell Gailey's Avatar
The procedure is in the workshop manual
BTW, if searching they are called side registers not vents. Vents bring up the defroster dash vents.
Old May 14, 2024 | 03:08 PM
RBaczek's Avatar
Default Any special tools?
Dell, thanks for information. In the manual it only addresses removing the door (after disconnecting the negative battery terminal), at the four points. It doesn’t address whether a special tool is required to pop the door off like a panel removal tool. Can you advise? TIA
Old May 14, 2024 | 04:50 PM
I've never done it, but it should "pop/snap" out just like the center console does.
Geewhite
Apr 14, 2021 08:21 AM
AaronLin
Mar 2, 2017 04:47 PM
Larry-Cleveland
Apr 9, 2016 02:34 AM
sonicd0012
Nov 3, 2015 04:52 PM
Jsedita74
Jun 5, 2011 06:08 PM
