A pool of coolant sitting below where the two metal pipes join
Old Feb 11, 2018 | 02:24 AM
Harry Peter Rose's Avatar
Default A pool of coolant sitting below where the two metal pipes join
2002 2.5 awd/auto..hopefully located coolant leak....left hand side of engine....a pool of coolent sitting below where the two metal pipes join..{just beside intake manifold}...not sure if coming the pipe joint?....where else could be the leak be from?...... Could it be the Intake Manifold Gasket or the dreaded Head Gasket ? ...Any thoughts most welcomed!
Old Feb 11, 2018 | 02:31 PM
Old Feb 12, 2018 | 02:03 PM
Fulton's Avatar
The best way to find a coolant leak is with pressure tester. Some auto parts stores will either loan or rent one. Its the safest way since the engine isn't running and the coolant isn't hot.
The best place to post issues with your car is under model specific section.
Attached Thumbnails A pool of coolant sitting below where the two metal pipes join-pressure-tester.jpg
Old Feb 12, 2018 | 03:07 PM
JBzXJ40's Avatar
The picture is a bit blurry, could you re-take and post a clearer picture.
Old Feb 12, 2018 | 04:42 PM
Default coolant!!!!...updated
Thermos andothers!....... Hopefully a clearer post than previous with picture
Needing help! 2002 2.5AWD auto./petrol located coolant leak / left side of engine...a pool of coolantsitting in valley below to the right of the where two metal pipes join {thisbeyond the oil filler) have used someone’s photo / blue circled location......
Could it be the dreaded Head Gasket ? {click on picture to enlarge}
Old Feb 12, 2018 | 05:08 PM
Originally Posted by Harry Peter Rose
2002 2.5 awd/auto..hopefully located coolant leak. .....
I've moved your question from Canada Region to X-Type forum. This is the place to post technical questions about your model.
Old Feb 12, 2018 | 07:03 PM
avern1's Avatar
GGG if you get a moment can you combine all 4 of the posts Harry has for this problem. We are responding but he can't seem to find his posts to review the responses.
Old Feb 25, 2018 | 06:19 PM
JBzXJ40's Avatar
@ Harry
You will most likely need to remove the upper and lower intake manifolds to gain access to locate source of leak.
There is a black pipe that connects to water pump and runs under the lower intake manifold towards the front of the engine. I have seen this pipe corrode through and leak. There should also be a rubber hose under as well, this could also be leaking.
Another possibility - in your picture, where the blue circle is. Just to the left of that is a junction, I've circled it in yellow. This is held in by 1 bolt, and there is an o-ring that has been known to leak. Odds are its the pipe or hose below the intake manifold.
Attached Thumbnails A pool of coolant sitting below where the two metal pipes join-x-typecoolantleak.jpg
Harry Peter Rose
Feb 13, 2018 08:14 PM
Harry Peter Rose
Feb 12, 2018 08:04 AM
Harry Peter Rose
Feb 12, 2018 08:01 AM
mattlowe
Apr 19, 2010 12:29 PM
mattlowe
Apr 18, 2010 06:40 AM
