Positive battery cable wiring
Old Aug 22, 2016 | 03:23 PM
Mgallard's Avatar
Default Positive battery cable wiring
There are two wires coming from the fuse box harness and are run along with the Power cable to the fuse box from the battery. These two wires are coming out of the fuse box harness, taped up with the fuse box power cable, exit about midway beneath the battery box, and have a two wire connector on the end. I cannot see where this connector goes, and it appears it was not plugged into anything when I started to remove the cable. What are these wires for?
Old Aug 22, 2016 | 03:58 PM
USarmor's Avatar
Mgallard,
I think what you are referring to is the Battery Isolation Device . . .
See the following link for the information you may need. NO worries - It does not connect to anything!
https://www.jaguarforums.com/forum/x...ry-wire-48600/
- Brian
Old Aug 22, 2016 | 05:39 PM
avern1's Avatar
+1 on the isolation connector. If you look closely at the bottom of the battery you will see a small tab sticking out. Tha'ts where mine is plugged in. You will find it fits the connector perfectly and is non-conductive.
Old Aug 23, 2016 | 02:25 PM
Mgallard's Avatar
Thanks guys! got it all put back together (replacing all parts of the positive and negative cables) and my alternator light does not come on randomly, the car actually shifts better (I sanded the ground surfaces on the transmission and the frame before landing those wires). My suspicion is there are a host of electrical "problems" that are related to poor grounding.
mark a l
Mar 7, 2020 03:53 PM
Ronco1
General Tech Help
Apr 21, 2016 12:37 PM
adenshillito
Apr 13, 2016 09:22 AM
Jagjagplayingup
Mar 29, 2016 03:11 AM
MRPAL
Sep 7, 2007 03:12 AM
