Powertrain and Check engine light is on
Old Sep 18, 2009 | 11:02 AM
BuckMR2's Avatar
P1111 just means that the car has finished running its checks when you turn on the ignition
P1643 is a CAN ECM/TCM network malfunction on at least 2 consecutive trips and is caused by anyone of these faults which means its either a short circuit,the transmission control module or the engine control module:-
  • CAN open circuit fault – TCM to ECM
  • CAN short circuit fault
  • TCM failure
  • ECM failure
When this fault code is triggered the car automatically outs the ECM into a safety default mode meaning
  • – Speed control inhibited
  • – Maximum throttle opening for N range inhibited
  • – Throttle opening limited to 30%
  • – Maximum engine speed reduced
Probably needs a good auto-electrician if theres a short circuit otherwise a specialist or dealer I would guess??
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
