Pulling Transmission and Transfer Case
Old May 27, 2014 | 04:20 PM
ltmax's Avatar
The company I bought the used trans from was very good about fully crediting back my money and I don't think they had any idea beforehand that it was such a piece of garbage. It was worth trying my luck with a used trans even though it didn't work out. It's funny, I've put in 5 junkyard transmissions over the years and 3 of them turned out to be time and money wasted. Each time that happened, I've sworn to never do that again..
When I finally decided to cut my losses and put a re-manufactured one in it, it worked out cheaper to pay my local trans shop to do the entire job than to pull it and install it myself.
On the plus side (if there is one) I did learn quite a bit about these transmissions in the process, and got to replace the leaking oil pan gasket and bad rear catalytic converter while the trans was out so it wasn't time entirely wasted and I discovered that most of the usual problems (cracked reverse/high piston and bad shift solenoids) can be fixed with the trans still in the car.
Old May 27, 2014 | 08:56 PM
car5car's Avatar
tel 904 353 5561 Mitchell transmission parts in Jacksonville
website Transmission Parts & Kits | Rebuilt Transmissions & More | Transtar, they also have store in Jacksonville
manuals:
https://www.atsg.us/atsg/new-releases-2.html
Jaguar has Nissan automatic transmission:
Jatco JF506E 5-speed medium/large
VW Golf, VW Sharan, MG Rover, Land Rover Freelander, Jaguar X-Type, Ford Mondeo, Mazda MPV
http://en.wikipedia.org/wiki/List_of..._transmissions
service manual
http://www.makcotransmissionparts.com/98400.html
Old May 28, 2014 | 02:30 AM
ltmax's Avatar
For any of you who want to try and fix this yourself, here are some good free files that helped me a considerable amount.
File Type: pdf
File Type: pdf
File Type: pdf
Old May 28, 2014 | 10:05 AM
car5car's Avatar
Thanks, neighbor!
Old Aug 13, 2014 | 04:31 AM
fourbyfourbyfar's Avatar
hi Itmax i have started to remove my gearbox and started to disconnect the drive shaft and some thick oil came out of the joint did you get this is this normal???
Old Aug 14, 2014 | 09:01 AM
ltmax's Avatar
The thick oil you see is some of the gearbox oil that has made it's way past the pinion bearing seal in the rear of the transfer case. It's harmless but probably a good indicator that you need to take the back cover off the transfer case and re-seal the shaft.
Old Aug 14, 2014 | 09:16 AM
when i drop the transfer case out was going to give it a oil change and check the seals as well cheers
Old Jan 15, 2016 | 04:15 PM
  #28
UKnFor-dluv-expat's Avatar
Default Did you do the video?
Originally Posted by Justicejamesb
Okay everyone,
I'm making a video series on how to rebuild the Jaguar X type JF506E Transmission and transfer case, along with the valve body!!! Hopefully everyone will subscribe to my youtube channel, or I might sell it for like $5 or something, but it's looking like it's going to be a youtube thing right now. Hopefully everyone will enjoy!
Yeah I have to replace my transmission and would love to view any helpful information. I might pull the engine and tranny, or will drop it not sure yet.
Hopefully just comments from those in the know, and withhold the "well if it was me comments" for expediency, that would be cool.
Old Jan 30, 2019 | 11:58 AM
James Johnson's Avatar
Default Help!!!
Hey I recently just took my starter off and found out the teeth are broke on flexplate. When getting a quote they said it was going to be a $2400 job including the price of the flexplate with is $250 max. I am pretty familiar with working on cars. I was just wondering what I’m looking at if I decide to drop the tranny myself and replacing the flexplate. I may just replace the whole tranny. What are the steps for tranny removal?
Old Jan 30, 2019 | 01:20 PM
  #30
Dell Gailey's Avatar
Main page in "stickies" has the downloadable workshop manual with step-by-step instructions.
Old Jan 30, 2019 | 01:25 PM
  #31
Thank you !
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Jpav27
Jul 31, 2022 06:43 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
mrplow58
Sep 9, 2015 11:27 AM
