Quarter Window Removal???
Old Jun 4, 2012 | 01:43 PM
PatMahjunk's Avatar
Default Quarter Window Removal???
Some tweekers smashed out my quarter glass last night. I called an auto glass specialist and they quoted me almost $400 to replace it I can source the glass for pretty cheap but I have no idea how to remove the old quarter glass. The replacement appears to include the trim also, seems like it all comes out as one unit. If anyone knows how to remove it please let me know.
One Pissed Unit
Old Jun 5, 2012 | 02:33 PM
disguay's Avatar
Pat, this procedure is covered in the JTIS. It would take me an hour to make this procedure with pics, so I would recommend just downloading the JTIS from the x type page. It is very helpful for things like this!
Remove the door panel.
Detach the interior trim which goes around the top of the window. (looks like an upside down horseshoe)
Remove the weatherstripping on the inside and outside of the window (stuff at base of window)
Then you remove what is called the window glass aperture seal which is on the top of the door.
With this seal removed, you should see a few rivets above where the top of the main window contacts the door: remove these
Then you remove the bolts holding in the rear glass and you got it made!
Old Jun 5, 2012 | 09:08 PM
PatMahjunk's Avatar
Are the rivets metal or just plastic rivets? Can they be re used? Thanks for the response.
Old Jun 5, 2012 | 11:14 PM
disguay's Avatar
I do not know. I just looked in the JTIS and it said to remove the rivets. Downloading the JTIS is simple though and if you plan on owning your car more than a couple months, download it! I didn't download it for almost a year and no I really regret it.
Old Jun 6, 2012 | 07:21 AM
spielnicht's Avatar
The rivets are metal, they need to be drilled out.
Get the JTIS...it's all in there.
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
sadepol01
Sep 11, 2015 05:26 AM
