Quick Question About ABS Sensor & Check Engine Light...
Old Jun 9, 2014 | 05:23 PM
DrBosco's Avatar
Default Quick Question About ABS Sensor & Check Engine Light...
Hello boys, On my 2004 Jaguar X-Type, AWD 3.0, I need my ABS Sensors replaced. My question is, Obviously the (ABS) light is on in the dashboard, would that also trigger the Check Engine Light as well?
For some reason my speedometer stopped working, haven't checked that yet, would that cause the check engine light to come on as well? I am hoping it is just the fuse.
Any help would be great, Thank You as always...
-Fred
Old Jun 10, 2014 | 06:27 AM
Thermo's Avatar
Veteran: Navy
DrBosco, if you have 2 wheel sensors that are bad, it can cause the speedo to not work (car doesn't know if it is getting a bad signal or no signal at all). This will also trigger the CEL too as it is putting up the error codes for a bad sensor (C1145/C1155/C1165/C1175). ONce you get the codes read and replace the sensors in question, lets see what you have at that point.
Old Jun 10, 2014 | 11:54 AM
mark a l's Avatar
HI i had the very same problem , abs + mil light on and no speedo also codes were c1165 and c1175 .. turned out both rings on the outer rear cv joints were corroded and snapped Quick Question About ABS Sensor & Check Engine Light...-2014-05-26-11.43.45.jpg
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Jaguila
Sep 5, 2015 06:16 PM
NinoGrimace
Aug 26, 2015 05:15 AM
Robgodius
Aug 25, 2015 09:34 PM
