Radio code after changing battery
Old Jun 30, 2015 | 07:08 PM
keithl's Avatar
Default Radio code after changing battery
Changed battery on 2008 3,0 X Type and whole touch screen blank as I expected. What I didn't expect is the screen to stay blank when I turn on, hold the power button; press various buttons, speak mystic phrases!!
What has happened? I'm going to crawl under the steering wheel to see if I blew the fuse but I'm not confident.
Any ideas people??
Old Jun 30, 2015 | 07:14 PM
santer's Avatar
Not sure where you are located but if in Europe and it is the original radio
radio code bypass code
If you in the USA then don't think they have codes
Old Jul 1, 2015 | 06:23 PM
keithl's Avatar
Default Radio, climate, NAV, etc not working after battery change
Maybe I'm not being clear ... I can't get the unit to come to life or ask for a Code. Is it likely to be as simple as a fuse - and if so which fuse is the likely culprit?
Everything was working perfectly before the battery change
Forcedair1
Sep 8, 2025 01:57 PM
philwarner
Oct 4, 2024 01:37 PM
cissdm
May 3, 2016 06:02 AM
Bowman
Sep 3, 2015 03:17 PM
OkieTim
Sep 2, 2015 12:48 PM
