Radio Heated Rear Screen
Old Apr 24, 2015 | 01:54 AM
Paul M P's Avatar
Default Radio Heated Rear Screen
Guys
X Type 2.2 Diesel 2007
Don’t know if this is know problem when using my radio the reception is fine but when I turn on my heated rear screen its very poor it does not mater what radio station or band I can only guess its because the antenna and heated screen use the same element?
I know in the grand scheme of thing it’s a small irritation as for 10 mins I can use the CD Player or whistle.
Just wondered is there a fix or do I have to just put up with it?
Old Apr 24, 2015 | 12:54 PM
euanT's Avatar
I have a similar problem in mine, cleaned all the terminals and earthing points, still the same!! further investigation needed!
Old Apr 24, 2015 | 03:19 PM
astromorg's Avatar
As well as checking the obvious connections at the rear screen and the head unit, there is also an antenna module that might be faulty. In the saloon it's behind the C pillar trim on the left hand side and in the sportbrake/estate it's behind the roof lining, on the centre line.
Incidentally, if you look closely at the layout of the heater elements and the aerial on the rear screen, near the centre stop light, you'll see that they are actually separate from each other.
Old Apr 26, 2015 | 12:03 PM
Paul M P's Avatar
Guys just checked the connections to rear screen and the antena amplifier all looks fine .
Do you think it may be worth getting a new antena amplifier are they know to break fail not sure how they work ?
Would appreciated any idears .
Old Apr 26, 2015 | 04:21 PM
astromorg's Avatar
If Eurojags can provide a used, but guaranteed one cheaply enough, it would be worth a try? Not many reports of them failing. I would think there's some arrangement of capacitors in them to act as interference suppressors, and there may be an amplifier of some description.
Jaguar Parts and Jaguar Spares from Eurojag - phone, don't email!!
FrickenJag
Jun 16, 2025 02:15 PM
philwarner
Oct 4, 2024 01:37 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
tberg
Sep 7, 2015 07:32 AM
