Radio and rear de-frost
Old Mar 5, 2013 | 11:49 AM
Fezz's Avatar
Default Radio and rear de-frost
This small yet odd problem doesn't bother me, but does anyone else lose their radio signal when you push the rear de-froster on? It's strange how weak the signal gets and goes static.
Was wondering if anyone has come across this before.
Old Mar 5, 2013 | 12:02 PM
Aonsaithya's Avatar
Yeah, it's "X-Typical". The radio antenna is very cleverly built into the rear window.
Old Mar 5, 2013 | 12:47 PM
WayneCountyBill's Avatar
Default Repeat But Still Good Topic
Yes; this topic was brought up awhile ago. On my vehicle, I don't loose the signal. I know that some owners reported that they receive static when using the rear window defroster and FM. "You gotta love your Jag."
Old Mar 5, 2013 | 01:40 PM
Fezz's Avatar
LOL figured this would be another common x problem. Thanks for the info guys :P
Old Mar 5, 2013 | 02:42 PM
Thermo's Avatar
Veteran: Navy
You can get rid of the interference by adding a noise filter to the rear defroster wire. This will cut down the amount of oscillation in the voltage going to the rear defroster, which will reduce the interference that it is causing. You can pick up an noise filter at some car stereo stores or at places like Radio Shack. Wiring them up is pretty straight forward. Just need to make sure you get the correct wire for the rear defroster.
Old Jul 20, 2013 | 04:31 PM
Dr dome's Avatar
Another issue solved by the almighty THERMO!!!!
Thanks ,
The Dr!
philwarner
Oct 4, 2024 01:37 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Burdedw
Sep 12, 2015 10:39 AM
TexasCat
Sep 8, 2015 04:36 AM
