Rear Control Arms / which ones to replace?
Old Apr 9, 2013 | 06:36 PM
afonda's Avatar
Default Rear Control Arms / which ones to replace?
Hi. I see there are 3 rear control arms on each side. (rear upper front / rear upper rear / and lower rear)
Tires are wearing on the inside edge. Which one should be replaced?
Old Apr 9, 2013 | 08:44 PM
Thermo's Avatar
Veteran: Navy
afonda, you need to replace the lower, front arm. 2 bolts and the piece comes out. After you replace the arms, then you will need an alignment done to get the tires facing properly.
Old Apr 10, 2013 | 07:39 AM
afonda's Avatar
Thermo... you said the lower front arm? From all the parts I have looked at there is a rear lower arm, a rear upper front, and a rear upper rear.
Then there are the control arms on the front of the car too.
Can you explain which one you are talking about. Maybe my information is incorrect. Just looking at a diagram from a jag dealer and they have the part listed as the "Lateral Arm". Is that what you are saying I need to change?
Thanks.
Old Apr 10, 2013 | 02:16 PM
Thermo's Avatar
Veteran: Navy
afonda, if you remove the wheel, you will see that there is an arm that is connected to the top of the rear suspension. Then you will see a large arm near the rear of the car that has the coil spring attached to it and then towards the front of the car, you will see an arm there on the lower side of the suspension. You want to replace this lower/front arm. If I can find a picture of what I am talking about, i will post it here and show you.
Old Apr 10, 2013 | 08:45 PM
afonda's Avatar
Default I think I found the part...
is this it?
Replacement Parts Catalog
Old Apr 10, 2013 | 08:50 PM
JagXV6's Avatar
Thermo, I thought the Mazda/Volvo arms you installed would take care of the tires wearing on the inside by correcting the negative camber??? Do the lower fronts need tobe replaced too???
Old Apr 11, 2013 | 07:39 AM
Thermo's Avatar
Veteran: Navy
afonda, yes, those are the arms that I am talking about. You will see them once you get the wheel off.
JagXV6, the wearing of the rear tires can be affected by many things. NOrmally the lower arms are the main cause for the inside edge tire wear. But, if the upper arm (the one you replace with the Mazda/Volvo arm) is significantly worn, then it can lead to inside edge wear. But, that is where getting an alignment will differentiate between the two. If your toe is still out, then that is the lower/forward arm, but if your camber is out (which the shop will tell you can not be adjusted), then you need to replace the arm that I recommended.
Old Apr 12, 2013 | 11:13 PM
Jeeves12's Avatar
Does this pic help?
Attached Thumbnails Rear Control Arms / which ones to replace?-4735530%5B1%5D.jpg
Old Apr 13, 2013 | 07:52 AM
Thermo's Avatar
Veteran: Navy
using Jeeves picture, it would be part #13 that I have been talking about. The replacement arm (the Volvo unit) is part #1 in that drawing.
philwarner
Dec 6, 2021 07:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
convincor
Sep 3, 2015 08:03 PM
frujag
Sep 1, 2015 03:43 PM
dpappyp
Aug 27, 2015 06:31 AM
