is this the rear diff drain plug?
Old Aug 8, 2014 | 07:38 PM
liquidreality's Avatar
Default is this the rear diff drain plug?
I am in the process of changing every fluid, was able to find good threads with picture locations of everything but the rear diff, pictures were detected from host server.
Sorry for the terrible angles, these were taken as if one were standing behind the car, looking towards the hood
Attached Thumbnails is this the rear diff drain plug?-img_20140808_203057.jpg   is this the rear diff drain plug?-img_20140808_203045.jpg
Old Aug 8, 2014 | 07:39 PM
They should really be rotated 90° cw
Old Aug 8, 2014 | 07:50 PM
Thermo's Avatar
Veteran: Navy
liquid, unfortunately, there is no drain plug. So, you are going to need to get some sort of suction pump to pull the old fluid out. You can pick up a cheap hand pump for around $15 to get the job done. Unfortunately, that is the reality of the situation since the rear diff is "filled for life".
Old Aug 9, 2014 | 04:13 AM
James Brandon Justice's Avatar
Default Drain and fill,
I drained and filled mine. I just got a cheap hand pump from HF and put in Royal Purple 75-140, works well. Stinky but easy job.
Old Aug 9, 2014 | 07:41 AM
Yes, I read the wire up, I have a decent pump that i used for t case and transmission, just wanted to make sure that was the plug I was after. It seems kinda high to be a drain, and low to be a fill, but it does have the same 3/8 plug that the transfer case has.
Thanks guys
FrickenJag
Jun 16, 2025 02:15 PM
Gus
Oct 15, 2019 12:29 PM
Bones
Sep 8, 2015 08:34 PM
obwoodie
Sep 3, 2015 07:45 PM
Bowman
Sep 3, 2015 03:17 PM
