rear pass window stops at 3/4
Old Jul 9, 2012 | 01:53 PM
al50bmgshooter's Avatar
Default rear pass window stops at 3/4
02 sport. The rear pass window wont go down the last 3"-4". Is that the motor going bad, regulator or something else?
resolved: the magnet came off the factory speaker and was stuck to the door
Old Jul 9, 2012 | 06:19 PM
disguay's Avatar
seems to me that your regulator has gotten jammed. I would just pull the panel and make sure nothing has gotten snagged somewhere it shouldn't be in there. If you need a new regulator, ebay, or rockauto
Old Jul 10, 2012 | 08:43 AM
thanks, I'll try that this w/e
Old Jul 16, 2012 | 10:58 AM
WayneCountyBill's Avatar
My right, rear window will not go down "automatically." My mechanic tells me I need a new memory for my motor (?). So, are you holding down the button until it goes all the way down or are you experiencing my situation? Hope this helps. Thanks. New Member Bill in Wooster OH
Old Jul 17, 2012 | 09:09 AM
no it goes down and up automatically, it just stops the last 4"
Old Aug 14, 2012 | 07:04 AM
vtraudt's Avatar
Let us know what is causing it. Post photos. Wire not winding up on the drive pulley?
Old Aug 14, 2012 | 09:47 AM
emaraszek's Avatar
I'm not sure if this is anything like the "auto up" function, but after I disconnected my battery to install my ACM a couple of my windows "forgot" how to go up automatically.
This is what I did to fix it:
1) Fully close the window
2) Press and hold down the button until the window fully opens
3) Pull the button up and hold it until the window fully closes
4) Repeat step 2
5) Pull the button up once like you do when you want it to auto close, hold it for 3 seconds or so
6) Try using the auto close and it should work
Maybe something similar to this could fix your auto down feature
Old Aug 15, 2012 | 10:06 AM
Default Thanks, Evan.
I will give that a try.
Attached Thumbnails rear pass window stops at 3/4-bill_auburn_sept2010_web.jpg
Old Aug 16, 2012 | 06:27 AM
no joy emaraszek. It was worth a shot thanks
Old Aug 16, 2012 | 08:52 AM
emaraszek's Avatar
Unfortunately, for your case it sounds like a bad piece of hardware somewhere, especially if you can't even fully open the window "manually" (i.e. holding down the switch)
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
