Removing Exhaust Tips
Old May 2, 2009 | 11:39 AM
whosjk's Avatar
Default Removing Exhaust Tips
Has anyone taken these off? Do they even come off? I'd like to replace them.
Old May 3, 2009 | 09:38 AM
JagXV6's Avatar
Best I can tell they are welded so they only way they are coming off is to cut them off.
Borla makes replacement mufflers for the X-Type. They say it is a cat back system but it is just the 2 Muffs.
http://www.borla.com/media/installations/140024.pdf
Old May 3, 2009 | 03:23 PM
MattSteele's Avatar
Yep, they're welded on. You should examine them carefully before tackling a project to remove them. Standard aftermarket tips won't fit because the the exhaust outlet doesn't come straight out of the mufflers - there's an S-bend in the pipes to clear the bottom of the bumper. You'd have to modify the new tips to fit and also custom fabricate a lower valance.
Your best bet might be just to go down the route of installing a borla system. I wish Borla offered a quad tip exhaust, but unfortunately they don't. Still their tips look larger and more aggressive than the OEM ones.
Old May 3, 2009 | 04:26 PM
Disco stu55's Avatar
Too bad, i was thining of just simply cutting them unscrewing the tips, and puting aftermarket ones on, too bad its not that simple
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Jandreu
Jun 30, 2022 03:10 PM
Jandreu
Jan 23, 2017 10:58 AM
Daim
Nov 28, 2016 09:28 AM
