Replace knock sensor and spark plugs project with pics (as requested) HOW TO
Old Jul 25, 2020 | 03:07 AM
  #61
Mahmood Suhail's Avatar
I have this coolant steel pipe spout leaking and one of the bolts is hidden under the cylinder head and nothing can reach it, no wrench or socket. Is there any way to get it out?
Old Jul 25, 2020 | 09:54 AM
  #62
UKnFor-dluv-expat's Avatar
Old Sep 22, 2020 | 09:26 AM
  #63
Fatih ÅžimÅŸek's Avatar
hello for jaguar x type AJ85676 is there difference between jaguar oem knock sensor and amazon ks305 sensor
Thank you
Old Sep 22, 2020 | 06:14 PM
  #64
keithet58's Avatar
Blaydes99 so it has been 9 years since this was done? Do you still have the X-type and is it still running well? I am getting ready to do this job. I was just going to replace coils and plugs but, I am going to replace that knock sensor since the engine will be open. do you only have to drain the coolant when replacing the knock sensor? I hadn't read anywhere about the coolant on replacing the plugs. thanks again for the great step by step info.
Old Sep 23, 2020 | 09:21 AM
  #65
blaydes99's Avatar
The X-type was running like a dream after the spark plugs and knock sensor replacement, but a few years ago we had an accident on the highway and the car was unfortunately totaled. Still have the Jaguar XF though, which is also running great. You are correct that you only need to drain the coolant for the knock sensor, mainly because of that last pipe that sits right on top of it. If you are doing the spark plugs only, I don't believe you'll need to drain any coolant, and will need to only remove the upper and lower intakes (and air box, etc... the usual stuff).
Old Sep 23, 2020 | 09:28 AM
  #66
blaydes99's Avatar
Thank you
Seems like it is compatible with the X-type from what I can tell. Just watch out depending on if you have a 2.5 or 3.0 engine to ensure it will work.
Old Aug 27, 2021 | 09:15 PM
  #67
Furmanator10's Avatar
Default Knock sensor.
I got to the knock sensor under the fuel rail on my 06 X Type and got the bolt out. Where does the other end plug ? I can't move it or trace it.
xjrjag
Nov 27, 2025 09:16 AM
fast40driver
Apr 19, 2024 07:24 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
DaveInVA
Aug 31, 2015 08:12 PM
dpappyp
Aug 27, 2015 06:31 AM
