Revered jumper cables and turned key
Old Mar 5, 2025 | 02:43 PM
Tj1224's Avatar
Default Revered jumper cables and turned key
So I am trying to help a friend out who accidentally reversed the jumper cable on 06 jaguar x-type (x400). The vehicle will not start and is show several codes such as P1638 - Can link engine control module/ instrument circuit. P1793 - ignition supply malfunction 167 V. There is a lot more from there but where should we start to get the car running again.
The engine turns over and doesn't fire off.
The large touch screen radio doesn't turn on and the climate control doesn't work either.
We have also replaced with new battery and check that it was good as well.
there are now fusesblown in the engine bay.
no fuses blown in lower driverside fuse panel.
Thanks for all the Help in advance!!!
Old Mar 15, 2025 | 01:56 AM
Roban654's Avatar
Yes i see this
Taylorerick5
Mar 3, 2023 12:32 AM
kolbe
Jan 25, 2021 07:28 PM
Jimmy Karlborg
Jan 18, 2020 09:18 PM
jag01
Mar 2, 2010 08:36 PM
