X-type starting problems
Old Jan 13, 2020 | 03:26 PM
Jimmy Karlborg's Avatar
Default X-type starting problems
Hello.
My name is Jimmy and live in Sweden.
I have problems with my X-type 2.0D 2005, one day it did not start anymore, nothing happens when trying to crank.
Battery is fine (charged and tried with cables from other car), fuses are fine, tried the ”reprogramming the keyfob” but nothing happens, changed battery in key (all buttons work on key). I think key no longer immobilises the car, lost the code to the car?
I have this errors:
P1000 On-board diagnostic (OBD) systems readiness test not complete:
P1260 Theft detected, vehicle immobilized
P1637 CAN link engine control module/ABS control module circuit/network malfunction
P1638 CAN link engine control module/instrument cluster circuit/network malfunction
P1699 CAN link engine control module/climate control module
I think I deleted P1260, but the others I could not delete.
On the dashboard it shows error: ”Errore dati computer carb”, translated to english with googletranslate: ”Carb computer data error”. Dont know what that means.
Do you think I only need to get instrumentcluster reprogrammed with key or some other problems?
Should starter crank when key on 3/crank if car is immobilised?
Very grateful for help.
Regards Jimmy
Old Jan 13, 2020 | 03:29 PM
I have read about ”immobiliser reset button”. Is this that button? If so nothing happens when pushed.
Old Jan 14, 2020 | 12:22 PM
edtoo's Avatar
Have you recently worked on anything electrical? The Can bus codes look like there is a problem on the Can Bus network, if this is broken the car will not start. This could be a problem with the ECU, check for water ingress. If anything has been disturbed like Dash Panel, Climate control then maybe a connection problem there, if not you will be looking for a broken cable.
Old Jan 14, 2020 | 06:31 PM
Thank you for answer 🙏
No not worked om some electrical.
Do you know where I can find the Can bus network?
Will check ECU for water ingress. Thank you
Regards Jimmy
Old Jan 14, 2020 | 06:38 PM
Dell Gailey's Avatar
When you turn key to position 2 (not start), does the MIL (little engine icon) remain lit?
Old Jan 14, 2020 | 06:46 PM
Hi and thank you for answer! Will check tomorow
Old Jan 16, 2020 | 02:01 PM
You think its bad clusterhouse or ECU or something else?
Old Jan 16, 2020 | 03:02 PM
Answer my question
Old Jan 17, 2020 | 04:06 PM
Originally Posted by Dell Gailey
Answer my question
sorry I have wrote another answer yesterday, dont know why its not here.
Yes the yellow engine icon is lit on position 2. what does that say?
I also removed the ECM and checked all electric connections I found, but could not see anything bad.
Old Jan 17, 2020 | 06:43 PM
If the MIL stays on constantly when key is in position 2 (not start), it means the car is not in "immobilizer" mode.
If the MIL goes out after a few seconds, this is Jaguar's built in indication the car is in "immobilizer" mode.
Old Jan 17, 2020 | 08:31 PM
Just to clarify that i looked at the right icon, is that the MIL?
If so car is not immobilised, thats good I suppose.
Old Jan 17, 2020 | 11:00 PM
Correct, if the MIL remains lit while sitting for several seconds in position 2 (not start). Some of the other lights will/may go out.
This may also help you as it looks like your gauges are displaying in Italian =
https://www.jaguarforums.com/forum/x...anguage-71213/
Old Jan 18, 2020 | 09:17 AM
Thank you man.
Okey so not immobilised. Is it more likely ECM or clusterhouse is broken? Maybe best to buy both from same car
Old Jan 18, 2020 | 02:42 PM
I would get it to a dealer to hook up to the computer to see which module(s) are having a problem. Take ALL your keys just in case they have to do a reprogramming.
Old Jan 18, 2020 | 09:18 PM
I dont really have any dealer near where I live. I will try to install the jaguar software on my laptop tomorow and see if Im able to handle that myself
dharry078
May 17, 2021 05:08 PM
Napster
Sep 4, 2019 04:47 PM
RenegadeRose
Nov 26, 2014 06:28 AM
bayezid_f1
Jun 26, 2012 03:48 PM
jag01
Mar 2, 2010 08:36 PM
