Reverse module plugs
Old Mar 9, 2020 | 10:09 AM
Sinbad's Avatar
Default Reverse module plugs
Hello, I've replaced my reverse module as it had got wet sometime before I bought my Jag and had corroded inside. My plugs have also turned green and I need to either clean or replace. Can anyone help me with A, How to remove the corrosion or B, give me the name of the plug connectors so I can get new ones . Thank you
Old Mar 9, 2020 | 07:33 PM
Thermo's Avatar
Veteran: Navy
Sinbad, I would start with a can of contact cleaner. That should get most of what you are after off. From there, while tetious, you will end up sitting down with a small scribe and essentially scratching at each pin to get the corrosion off to restore the pins to a bright, silver finish.
reko19
Nov 4, 2017 12:58 PM
Mr F
Sep 15, 2017 03:37 AM
Capitalman1
Jul 16, 2014 08:53 AM
jagpro69
Sep 7, 2012 07:28 AM
adriaxj8
Sep 7, 2012 06:34 AM
