Right rear ABS sensor 05 X-Type
Old Jan 10, 2019 | 01:37 PM
heldt4's Avatar
Default Right rear ABS sensor 05 X-Type
Just replaced the right rear sensor on my 05 X-Type. Not even 30 days and the abs light came on and the code shows right rear. Any ideas what could be wrong?
Old Jan 10, 2019 | 01:44 PM
Welcome to the forum heldt4,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X-Type forum. This is the place to post technical questions about your model.
Old Jan 10, 2019 | 01:53 PM
JagV8's Avatar
Bad bearing, bad (new) sensor, bad wiring, etc.
Old Jan 10, 2019 | 03:36 PM
astromorg's Avatar
Check out the reluctor ring - the toothed/corrugated ring around the drive shaft that the sensor senses. They can corrode and break causing your sort of problem.
Old Jan 10, 2019 | 03:41 PM
heldt4's Avatar
actually I checked the reluctor ring before I installed the new sensor and there were no cracks. It is somewhat rusty, but nothing out of the ordinary
Old Jan 22, 2019 | 09:51 AM
heldt4's Avatar
Default ABS
I installed a new sensor and it seems to be working fine. Now I am feeling the ABS engaging on dry pavement. No light on the dash. Any ideas? Could it be the ABS control module?
davesjag
Oct 5, 2024 04:09 PM
boringb5
Dec 14, 2018 05:20 PM
Mike Noneofyourb
Nov 15, 2018 11:18 AM
