Rough Idle and Engine Running Rich 2001 3L Jag X-Type
Old May 31, 2018 | 09:07 PM
  #41
SannaT's Avatar
It's something Ive always been wanting to do but I do get scared of damaging anything especially when my dad tells me off for topping up my own oil and brake fluid.
I am going to try to the battery myself it doesnt seem complicated, not with the help of a YouTube video
Old Jun 7, 2018 | 10:50 PM
  #42
SannaT's Avatar
Turns out the battery in my car was the wrong one. It was 720 CCA instead of 790. Going to install the new one today.
Old Jun 8, 2018 | 12:12 PM
  #43
dwclapp's Avatar
SannaT: After replacing the battery, you'll need to reset a few features. Very quick and easy, described in this thread:
https://www.jaguarforums.com/forum/x...cement-144778/
Old Jun 8, 2018 | 01:41 PM
  #44
Alfadude's Avatar
The CCA (Cold Cranking Amps) rating wouldn't affect anything, unless you are trying to start the car in extreme cold. If you needed a new battery it would be because it isn't holding a charge and not outputting the correct voltage. It wasn't that it was the "wrong" battery, that is unless you had something that was meant to be used on something like a riding mower.
How old is the battery you currently have in your car?
Once you get the new battery in see what you have. Read and then clear any codes that show up and see if any come back. Post here whatever coes show up.
Old Jun 8, 2018 | 05:06 PM
  #45
SannaT's Avatar
The battery was 17 months old it started with giving me problems when it was cold.
Old Jun 8, 2018 | 05:10 PM
  #46
SannaT's Avatar
I fitted the new battery yesterday. It's still rough idling when the engine warms up but I haven't checked for any codes yet
Old Jun 8, 2018 | 07:48 PM
  #47
dwclapp's Avatar
SannaT: Is the check engine light on? If 'yes', then definitely check the codes and let us know what you find.
Is it rough only when idling after the engine warms up? What about at highway speeds, and also when idling before the engine warms up?
Old Jun 8, 2018 | 07:51 PM
  #48
SannaT's Avatar
There is no engine light. Sorry it's only rough idling before then engine warms up. Once it's warm it runs perfectly. I haven't taken it fqr enough to drive above 100km/hr but it still drives well especially when I chuck it into sports mode
Old Jun 9, 2018 | 12:28 AM
  #49
dwclapp's Avatar
SannaT: Reading thru this thread, the common theme is a rough idle before the engine warms up. Back in post #3, avern1 suggests the problem could be either a vacuum leak or a dirty MAF sensor, and JagV8 agrees in post #7. I'm on the same page. Here's why.....
The symptoms you describe are a rough idle when cold, a smoother idle when warmed up, and good performance at highway speeds, with poor gas mileage of 16.5 L/100km (~14 MPG) on a relatively high mileage engine - 190,000km (~120K miles). This sounds like a vacuum leak that is allowing extra air into the engine, causing a lean fuel / air ratio.
A cold engine prefers extra fuel, aka a rich fuel / air ratio, until it warms up. But the vacuum leak allows extra air in, causing a lean fuel / air ratio, so the cold engine idles poorly.
After the engine warms up, air still leaks in, so the fuel / air ratio is still lean, but the warm engine tolerates this better and idles more smoothly than when cold.
So why does the engine with a small vacuum leak run well at highway speeds? Because it 'inhales' 3-4 times more air than at idle, like a runner breaths faster than a walker. The fast breathing engine barely notices the extra air from the vacuum leak. The gas mileage suffers, but the performance can seem ok otherwise.
avern1 suggests three simple remedies back in post #3. Take a look at them and tell us what you observe. They're inexpensive and common for our X-Types. The post below has additional info on 2 of the 3 remedies avern1 suggests. If these remedies don't pan out, let us know and we'll walk you thru checking the fuel trims with your Torque app.
https://www.jaguarforums.com/forum/x...1/#post1309725
Old Jun 9, 2018 | 12:44 AM
  #50
SannaT's Avatar
Thanks will try them
yaknuts81
Jun 7, 2017 12:04 PM
chuckjag
Apr 24, 2017 10:19 AM
xsolo47
Jan 5, 2017 03:41 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Ricky3r
XJ40 ( XJ81 )
Mar 30, 2010 09:39 PM
