Rough idle & misfire codes
Old Jun 28, 2010 | 09:33 AM
pdowning6's Avatar
Default Rough idle & misfire codes
Hi all, I have a 2002 3.0 with 120k on it. Yesterday driving in the rain started to idle rough & CEL came on over 2500 RPM and cruise not available display lit up. Checked codes this morning & had 10 codes. P0301,303,1313,0158,0351,0353,0355,0430,1367,1000. I cleared all of those then ran the car again. I am consistently getting either p0300 with p1316 or p0303 with p1313. Only happens when I hit 2500-3000 rpm but idle is still rough. Any ideas out there on what could be causing this issue?
Thanks n advance for any help,
Pat
Old Mar 6, 2012 | 08:58 AM
done's Avatar
I have the same thing going on.... I'm thinking I have a bad head gasket between the 3 & 5 cyls. Are you losing water & blowing white smoke?
Old Mar 6, 2012 | 09:00 AM
done's Avatar
done61@windstream.net let us know .... when you find the remedy
Old Mar 9, 2012 | 06:07 AM
Mohammed Marwan's Avatar
check those things , similar problem to mine .
Dirty air filter
MAF
Spark plugs may be dirty or worn
Spark wires may be bad
Ignition problem
Fuel filter may be clogged
Water in the gasoline
Carburetor may have a bad accelerator pump or power circuit
Catalytic converter may be clogged
pcv hose rupture .
gd luck .
Old Mar 11, 2012 | 03:29 PM
jagone's Avatar
Default Try This
I had the same problem on mine, 1-6, it was a plenum leak, and bad Injector o-ring's, Now here's the rub, That is a ford Engine, built in Cleveland Ohio, specifically, an LS engine. SO you can either pay jag to do the work, or find a mechanic you trust, who will not see the cat on the hood, and only a Bue Oval. I took me a week to get my people to realize that, one they did, if cost me a third of what jag wanted. Food for thought, hope this helps.
Old Mar 12, 2012 | 05:20 AM
jagryan85's Avatar
hi, it sounds to me as your ignition coils are on the way out. These are common faults on higher milage engines, probs best to replace spark plugs at the same time, Ryan.
Old Mar 12, 2012 | 08:13 AM
done's Avatar
Default Did that
Replaced the 1 3 5 coil paks and plugs.... still have misses & limp mode
Old Mar 12, 2012 | 09:33 AM
jagryan85's Avatar
what about cylinders 2 4 & 6? Its often rare all 6 can go at once, but saying that it has been heard of. Also, as mentioned above, the oil breather pvc hose are prone to splitting from underneath. Its located at the top of engine and goes from manifold to cam cover, only 2 mins to check. Hope you sort it mate i know its a right pain in the a*s when sh*t hits the fan!!
Bcrary3
Feb 21, 2023 04:29 AM
Mac Allan
Oct 27, 2015 04:49 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
mrplow58
Sep 9, 2015 11:27 AM
Bowman
Sep 3, 2015 03:17 PM
