Running problem
Hi guys I am hoping someone might be able to help me with a problem with my car I have a 2008 2.2 x type and my problem is when at slow speeds it seems as if every minutes it feels like it is being pulled back a touch then stutters then clears for another minute or so and it gives a bit of smoke when you accelerate then clears and the car runs fine I am also only getting 26 miles to the gallon it shows warning lights and no fault code I have replaced the turbo actuator with a reconditioned unit cleaned the maf sensor replaced the cam sensor,map sensor fuel filter air filter and a new egr valve and have had no luck rectifying this fault and I am at a loss on what to do now I love this car but this is driving me mad any help would be appreciated thanks.
- hi sorry for the delay in getting back to you I lost my phone it is a manual 2.2 sovereign.
That symptom would normally be sticking egr valve or air being drawn in on the fuel line.
As the fuel injection pump has a built in lift pump, and the highest fuel line points is around the filter that also has o ring fittings, I would suspect that area.
Also if your new egr valve is non genuine one, don't rule out that this may be faulty.
Paul.
Paul.
shootingbrake
Sep 23, 2015 10:54 AM
