S-Button Won't Come On
Old Jul 5, 2008 | 04:05 PM
alarsen77's Avatar
Default RE: S-Button Won't Come On
Well do you notice that it is shifting differently when you do push the button? Cause my only guess is that maybe it is activating and the light has gone bad but you just don't know when it is on or off. That is all i can think of not really sure how to test it other than driving it and then pushing the button and seeing if it holds gears longer.
Old Jul 6, 2008 | 10:05 AM
w.neurauter's Avatar
You should also be able to determine whether it's actually activating by seeing if it goes into 5th gear before 50 mph. Unless they changed it my 2002 will hold 4th gear with the S button activated unless you're going over 50.
Old Jul 9, 2008 | 12:03 PM
The World Tour's Avatar
I have the same problem, sports mode will not switch on. I had a small leek of transmission fluid which was fixed. Anyone know how to clear the code?
I don't have access to a jag scan tool but do have a regular generic scan tool.
Old Jul 10, 2008 | 04:01 PM
ancientsanskrit's Avatar
...disconnect the battery and reset the pcm?
However, the code will come back again once the pcm cycles. So probably not much of a point to it.
Old Jul 10, 2008 | 05:57 PM
How do I reset the PCM is it just by disconnecting the battery?
Old Jul 10, 2008 | 07:08 PM
ibjags's Avatar
get it checked for codes FIRST
n2audio
19
Jan 20, 2025 09:35 PM
jluckcuck
Nov 6, 2015 07:49 AM
audibabba
Oct 4, 2015 05:41 PM
blackenedindustries
Sep 30, 2015 10:17 AM
Listers
Sep 30, 2015 07:45 AM
