S-Type wheels fit on X-Type?
Old Oct 1, 2009 | 01:44 PM
Pete04xtype's Avatar
Default S-Type wheels fit on X-Type?
I came across a great deal on 17 inch OEM Jaguar wheels. The wheels are 17 inch and they look like they are off a S-Type.
17x71/2
1) They seem like they will fit.. Will they?
2) Anyone else running S-Type wheels on their cars? Post some pics..
Give me some input. And here are the pics of the wheels.
Attached Thumbnails S-Type wheels fit on X-Type?-100_0492.jpg   S-Type wheels fit on X-Type?-100_0493.jpg   S-Type wheels fit on X-Type?-100_0494.jpg
Old Oct 1, 2009 | 05:38 PM
Thermo's Avatar
Veteran: Navy
Pete, the wheels should be interchangeable. So, if you can get them. go for it. They have the same backspacing and bolt pattern. So, you should be good.
Old Oct 1, 2009 | 08:03 PM
That is what I was looking to hear.. I will pick up some new tires and they should look good on my X-Type..
Old Apr 14, 2018 | 06:04 PM
neo17's Avatar
Sorry for Reply in an old thread but have the same worry as in it. Wondering if 17 inch S Type rims do fit for 2003 X type. I am looking at a good offer of Juno s Type rims. The owner has not much info on the technical details. I understand that they won't fit with tires 235/50 and also the offset is 60 instead of the 50 desired offset of X type. Will this be a problem?
Old Apr 15, 2018 | 03:19 PM
x_type_lpg's Avatar
I had to fit spacers when using s type wheels so the tyre did not rub on plastic lining in front wheel arch when on full lock
Old Apr 15, 2018 | 03:56 PM
neo17's Avatar
Probably I should stay away from them then, I don't rellre want to buy spacers as well.
Old Apr 16, 2018 | 08:16 PM
Lemons Racer's Avatar
I'm curious about this and started searching for a wider tire as well. My thought as to why it wouldn't fit is the tire on it is a 235/50 17 while stock is 205/55 16. Your tire is actually has a wider diameter. The goal is to have a tire with the same diameter, just wider. Otherwise you will also throw off your speedometer as well as potentially rub. 225/45 17 is a factory fit.
dsnyder586
Dec 29, 2024 07:39 PM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
