Sat Nav Help!
Old Aug 26, 2012 | 02:59 PM
Bandit1985's Avatar
Default Sat Nav Help!
Evening Gents,
I am encountering problems with the Sat Nav fitted to my 08 X Type Sport Premium. When I attempt to put in a post code it states that the data base doesn't recognise it?
I have tried different post codes and most are established codes so I would think the data base would recognise them? I have looked at the settings and all seems to be in order. The disc I believe states 2007-2008.
I am new to Jaguar ownership so any advice would be appreciated
Many Thanks,
Old Aug 26, 2012 | 04:15 PM
ballina226's Avatar
Hi had the same problem with mine at first. Have you tried the postcode with or without the space. From memory it works one way but cannot remember which. I will have a look at mine in the morning.
Regards
Old Aug 27, 2012 | 03:47 AM
Bandit1985's Avatar
Hi
Yes I have tried using a space and it still struggles to find anything. I have better luck if I use the street name though. Anyway thanks for help.
Old Aug 27, 2012 | 08:57 AM
ballina226's Avatar
Hi Paul
Just had a go with my satnav and the postcode search works (with a space) although it would not find my old works postcode but this may have changed.
I have the latest maps which I think are 2011/12.
Regards
Steve
Old Aug 28, 2012 | 05:29 AM
Bandit1985's Avatar
Thanks for that. I am going to try and source an updated disc 11/12 if I can. Not sure of anyone who sells them? I guess main dealer would be a ridiculous price.
Old Aug 29, 2012 | 11:13 AM
tanis8472's Avatar
I had that until I checked the map area being used. Mine had defaulted to the Netherlands. Put it to UK and worked fine.
Its in the settings somewhere, I think you need to press the menu button. Its below the screen next to the volume knob.
Finbarr1975
Sep 5, 2025 08:38 PM
Paora
Feb 4, 2021 12:36 AM
Finbarr1975
Oct 4, 2015 05:32 PM
CaptainHam
Oct 1, 2015 02:01 AM
