Seat problem
Old Oct 4, 2009 | 12:55 PM
Disco stu55's Avatar
Default Seat problem
My drivers side seat won't level out, the tilt forward function has some how diable itself, all the other functions still work, any ideas on how to fix?
Old Oct 4, 2009 | 01:29 PM
Wankel's Avatar
I have a similar problem with mine, the front tilt works but the rear height adjustment doesn't.
Old Oct 4, 2009 | 02:29 PM
FearTheLeaper's Avatar
I have the same problem too, I can go forward and backward just not up and down.
Old Oct 4, 2009 | 02:35 PM
Striker27's Avatar
lol
If you can still hear the motor trying to work then look at the spring shaft that goes from the motor to the mechanism that moves the seat.
Old Oct 4, 2009 | 02:39 PM
yeah mine don't go up and donw, but i don't car abut that, as long as i can control the tilt, now any soltuions to this problem
Old Oct 4, 2009 | 05:15 PM
Striker27's Avatar
Sure I replaced my spring shaft.
Old Oct 4, 2009 | 09:20 PM
really thats it, how much was it
Old Oct 5, 2009 | 02:12 AM
Striker27's Avatar
Well you have to find one. I do not remember what I ended up paying for mine. It is cheaper then a seat track though. You can make one out of a few things old speedometer cable with the ends squared off come to mind.
Old Oct 5, 2009 | 06:56 PM
Alrighty then, what does it look like, and are there diffreent types of spring shafts. Where can i get one and how hard is it to install
Old Oct 5, 2009 | 07:42 PM
Striker27's Avatar
Well it looks like a wound up spring. I have used a old speedometer cable and ground down the ends to make them square. One end goes to the motor other end to the mechanism that moves the seat. 5 minutes to install it.
Old Oct 5, 2009 | 10:00 PM
you wouldn't happen to have any pictures would you
Old Oct 6, 2009 | 01:42 AM
Striker27's Avatar
Sorry I do not have anymore. If you look under the seat you should be able to see them though. They are a little thicker then the replacement ink on a ball point pen!!!
Just take your seat out takes maybe a few minutes at most..
Old Oct 6, 2009 | 07:54 PM
lol, maybe il just pay someone to do it, i looked under the saet and it looks pretty complicated, hmm, maybe if i shine a bit of light i can see the problem.
Old Oct 6, 2009 | 08:32 PM
Striker27's Avatar
It was around $1100 US to fix the seat here.. Not hard to take it up and have a look just do not move the controls!!!
Old Oct 6, 2009 | 08:36 PM
okay, yeah if its 110 there its proabaly 1800 to 2000 up here, hmm, i hate thses issues with the car, ill have to fix it somehow
Old Oct 6, 2009 | 08:55 PM
LAD's Avatar
LAD
No seat problem yet, but I've posted my question regarding rust!!! help !! and have no responses. you have an x-type, do you know anything about this issue ???
GordoCatCar
Jan 2, 2017 01:10 PM
jdzubas
Oct 4, 2015 09:14 AM
jehart49
Sep 12, 2015 05:36 PM
Dallas XK8
Sep 3, 2015 12:17 PM
dcvickers
Sep 2, 2015 06:14 PM
