shifting cable
Old Feb 9, 2010 | 01:12 PM
jane152's Avatar
Default shifting cable
We just had the transmission overhauled on my 2000 x-type 4.0 (v-8) and the cable needs to be adjusted or replaced. Currently reverse works, but I have to shift it into second then to 4th, before I can put it into drive. The problem is how do we get to that cable? The guy thought he could do it from underneath but not possible. Can any body help?
Old Feb 9, 2010 | 02:16 PM
Brutal's Avatar
you take the steel curb protector off the bottom of the trans to expose the shifter cable and its adjustment...this isnt the same guy who rebuilt the trans is it
with the trans in nuetral and the shifter in nuetral, loosen the set bolt to relieve tension, then retighten. reinstall cover and youre done
Old Feb 9, 2010 | 04:37 PM
Alfadude's Avatar
Jane, are you SURE you have an X-Type...and that it is a 2000 model? I think you meant to post this in the S-Type forum.
Old Feb 9, 2010 | 05:53 PM
Brutal's Avatar
Nice!!!! and with a 4.0 V8, now we're talking.....shows you how close of attention I was paying
ON the Stype there are 2 things to be aware of
1) the cable go bad, the sheath down by the trans pulls from the crimp part of the bracket on the trans and your adjustment will never stay. if its pulled back replace it,
2) you adjust the cable inside the car on a stype. remove the console top and access the 2 lock nuts on the cable. adjust as needed again in nuetral till the cable gives EQUAL freeplay on both sides of nuetral. personally I would replace the cable due to issue of them loosening and they can defintily cause trans failure from not having the trans fully in gear(even though the shifter looks like it is) If the trans CLICKS cannot be felt as you slowly move the shifter through ALL settings including the J gate on the left it is not adjusted correctly!!!
Old Feb 9, 2010 | 08:26 PM
Alfadude's Avatar
X-Type, S-Type....what's in a letter anyway???
Old Feb 10, 2010 | 07:33 AM
The Chris X's Avatar
I was just wondering how I could get my hands on an X type with a 4.0 V8 !!!!!
Old Feb 10, 2010 | 11:58 AM
jane152's Avatar
sorry, I meant S-type, I am just so aggrivated with the guy who did my car.
are cables expensive????
You guys are so great for answering
Old Feb 10, 2010 | 12:13 PM
Brutal's Avatar
Go to nalley jaguar's website here and price it. You can pull up everything for your car with pics and prices
jimforrest (uk)
Feb 28, 2019 06:42 PM
adam699
Oct 13, 2015 05:53 PM
tomkilner
Oct 9, 2015 07:10 AM
10 XF Premium
Oct 2, 2015 09:22 PM
Johnken
Oct 2, 2015 10:12 AM
