Shifting Problem 2006 X-Type
Old Mar 13, 2025 | 01:47 PM
Floatcat's Avatar
Default Shifting Problem 2006 X-Type
2006 X-Type Estate 3.0.
Got the car running, but will only shift into reverse or neutral.
The shaft going into the tranny that attaches to the front end of the shift cable is corroded is hard to turn.
Should be able to turn easily by hand when the cable is removed, but now requires vise grips or channel locks.
Would spraying with Kroil or Kimball Midwest, loosen this up enough to shift?
..... or does this require extensive tranny work?
Old Mar 13, 2025 | 04:15 PM
h2o2steam's Avatar
Hi Floatcat,
Likely you have the corroded shaft binding within the plastic bushing....
Check out this thread, particularly post #10
https://www.jaguarforums.com/forum/x...-fault-206869/
Old Mar 13, 2025 | 08:25 PM
Floatcat's Avatar
That's sounds like it might be right. Where will I be able to find a replacement bushing for that shaft?
Floatcat's Avatar
.... and thank you for the info & the link to the other thread.
Old Mar 14, 2025 | 01:43 AM
Dell Gailey's Avatar
Old Mar 14, 2025 | 08:51 AM
Floatcat's Avatar
Excellent info; I trust that the bushing/sleeve is the same for both automatics and standard shifts?
Thank you!
Old Mar 16, 2025 | 01:33 PM
Floatcat's Avatar
The selector shaft sleeve is "obsolete" ... unavailable form any sources; Jag dealers, Jag Bits, Welsh, etc.
A used one will probably be junk and I doubt any boneyard will extricate one from any salable transmission that they may have in stock. So it looks like I will have to make the part.
I'm pretty sure mine will be toast by the time I get it out. Does anybody know where I can get the specs for this part so I can have fabricated? ...... possibly 3D printed?
xj804
Jul 1, 2022 01:16 PM
Jag Driver
Feb 5, 2015 02:14 PM
magicjuan17
Mar 6, 2014 08:03 AM
Ba cn br
Mar 6, 2014 07:54 AM
st.clair
Dec 3, 2011 06:40 PM
