Should I buy? If I do, what do I watch out for?
Old Dec 3, 2007 | 06:54 PM
nineball's Avatar
Default RE: Should I buy? If I do, what do I watch out for?
price seems fair enough, depending on what options it has. for a base model with no toys that seems a bit high, but not unreasonable. you will still have the factory warranty until 50k or 4 years from the in-service date, which could be as far away as 12-08 in a best case scenario. there isn't anything persay that goes wrong with all 04 models, but the biggest reported problem has to do with replacing the prop (drive) shaft.
some options to look for are: sunroof, HID lighting (will have little washer spouts outisde), heated seats, power passenger seat, navigation system (big screen where the radio is), cruise, rear parkingassist (4 sensors visible on the bottom of the rear bumper), trip computer (3 buttons underthe headlight switch).
also, try the big 3 to check prices in your area, with your options:
www.kbb.com
www.nada.com
www.edmunds.com
Old Dec 4, 2007 | 04:14 AM
Cadillac's Avatar
Jaguar have been quite reliable namely from late XJ40s . When it comes to X Type you should buy it a model aslate as possible .Being a '04 you should watch out thetranny and make sure if maintained and not abused .I don't think you will regret .
Whatever you buy hope you like and happy with it
Old Dec 4, 2007 | 03:42 PM
aquill1's Avatar
That is a steal for that car imo. Depending on the options whether its 2.5 or 3.0 and what not. It should be under warranty and if it is you can also purchase a select edition or extended warranty through jag for less than 2k if it doesn't already have it. This way even if there are problems you can take it directly to a jag dealer and let them fix it. These aren't any worse than any other car imo as well. Every car has its problems whether or not its import, american or luxury...
Old Dec 4, 2007 | 05:54 PM
jag_genius's Avatar
04 are usually good.. trani's are good in them finally.. just shifter assembly's ,transfer case,
Old Dec 5, 2007 | 08:37 AM
bigdreams05's Avatar
I'd say go for it. Like Aquill said, any car can have problems, so get the extended warranty. You'll have a solid car and peace of mind. The 04 is a very solid model but I think it could be a bit cheaper, unless it's absolutely immaculate and has a few extras.
Old Dec 5, 2007 | 12:20 PM
BuckMR2's Avatar
Is that £15k or $15k?
Done around 24000 miles in over 2.5 years ownership and no probs with my 02 3.0 most reliable car I have owned in 23 years.Only had minor problem with a wheel speed sensor which was replaced under theaftermarket warranty that came with the car.Get one or regret it
Old Dec 5, 2007 | 03:48 PM
RudyF6's Avatar
Aquill, Where did you get a quote for extended warranty for less than 2k? Was there a big deductible?Novi gave me a figure closer to 3k for a no-deductible 100,000 mile plan!
Old Dec 5, 2007 | 06:10 PM
jasonzimbran's Avatar
Aquil you paid under $2k for a extended warranty?
Old Dec 5, 2007 | 08:09 PM
Did you see the car on ebay, the one on ebay its a 2004 jaguar x-type 3.0 and it has 26000 miles, it HAS A SALVAGE TITLE, watch out DO NOT BUY IT.
Old Dec 5, 2007 | 08:27 PM
Hey Eddie...........go for 04 or above if you can as most of the teething problems / issues have been ironed out since then. Although my 02 with 16K on the clock when I got it has covered another 12K in the last year and I have had no trouble at all.
Get yourself a good warranty like everyone says for peace of mind and you'll be good to go
Welcome to the forum btw
Jim
Old Dec 6, 2007 | 09:50 PM
aquill1's Avatar
No I don't have a warranty for mine but I asked the 800 jag number a hypothetical question if my car had 4k less miles could I purchase the jag warranty and it was just under 2k...and that was straight through jag...I don't know why novi told you that rudy??? I got that quote directly from jag not at a dealer...they might have tacked on some gratuity! There's no sense in buying the jag warranty for that when you can get an aftermarket for under 3k...
Old Dec 7, 2007 | 08:07 AM
RudyF6's Avatar
ORIGINAL: aquill1
I assumed that, but not THAT much! Sheesh, for that much money, I can fix alot of problems myself! (And so far, I haven't had any..... is there a "knock on wood" smiley?)
Old Dec 7, 2007 | 02:20 PM
aquill1's Avatar
surprised there aren't any!!!
Old Dec 7, 2007 | 05:07 PM
Cadillac's Avatar
Knock on wood .....OK, but what kinda wood ? Burl ,burl walnut, walnut , zebrano,cherry ,filbert ....rofl
What if you have aluminum trim in your car ? Then knock on aluminum you say [:-]
duecedriver
Dec 25, 2015 11:47 AM
Jaguar Forums Editor
Jaguar Press release
Sep 14, 2015 11:18 PM
Chuck Schexnayder
Sep 12, 2015 10:30 AM
