slightly smelly X-type - oily smell when sitting still
Old Feb 6, 2008 | 05:28 PM
FactoryJaguarTech's Avatar
Default RE: slightly smelly X-type - oily smell when sitting still
Sounds like your cam cover may be leaking.
Old Feb 6, 2008 | 09:03 PM
Dennis's Avatar
ud
Pictures please..I smell a faint little hot engine oil smell myself every once in a while, just after pulling into the garage...Just as you, figured it was the oil that soaked into the exhaust pipe coupling just down stream of the cat from the last oil change...
Old Feb 6, 2008 | 09:43 PM
The oil smell after oil change should burn off within a few miles. If you are smelling it consistently, i would look at oil pan, front crankshaft seal and cam cover gaskets....in that order.
Old Feb 7, 2008 | 01:45 AM
Mr T's Avatar
hi there,
dono if this will help but i had the same problem on my other car (Saab 95), smell of oil coming through the vents, it turned out to be the breather pipes for the oil circulation. apparently this is a common failure on Saab 95's where the breather pipes become soft (worn) and as such they split after some time causing oil fumes to escape into the engine bay and subsequently into the vent intakes. so if you cant see oil leaking, maybe check your oil circulation pipes. i know its not the same car, but maybe the problem is similar. hope this helps.
T
Old Feb 7, 2008 | 05:38 AM
Nice tip Mr T.
Bo I will get you the plug number.
Old Feb 7, 2008 | 09:03 AM
Dennis's Avatar
ud
My oil pan and everything I can physically see is dry and oil free
Old Feb 7, 2008 | 03:19 PM
What about cam covers? Mirror and flashlight for the rear cover to see you will need.
Old Feb 7, 2008 | 06:21 PM
Did the plug info I gave you help or no? Just curious as it may help others if you post the number you got.
Old Feb 8, 2008 | 06:31 AM
Glad it worked out. I meant to tell you, if they have a 7g stamp on them somewhere, dont use them. Apparently bad resistors.
New service action for us to check them in 2008 x-types. I think they only came from factory though.
Old Feb 8, 2008 | 02:50 PM
Dennis's Avatar
ud
Screw it..I don't smell it much anymore..So if it ain't dripping on to the floor or I can't see anything or messin up the underneath, it ain't enough to worry about.
Old Feb 10, 2008 | 09:01 AM
Nice tip ignacio. And welcome to the forums.
Bcrary3
Feb 21, 2023 04:29 AM
way2far
Aug 31, 2022 09:26 AM
Jandreu
Jun 30, 2022 03:10 PM
mrplow58
Sep 9, 2015 11:27 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
