Sound system "speaker" question...
Old Apr 1, 2014 | 03:37 PM
timetraveler1's Avatar
Default Sound system "speaker" question...
About 8 months ago I had my dead front and rear right-side main speakers replaced at a local sound shop. Good job, reasonable price, no complaints.
So last week, the front left speaker(in lower door) quit. I took it to the same shop today for replacement. Now sounds great.
BUT... Now the door won't open from the inside until the electric locks are set and reset a couple of times - and even then you've gotta pull on the handle too hard.
MY QUESTION... Did the audio technician have to remove or loosen the interior door panel to change out the speaker? I need to know before I give the shop a call to discuss the issue.
Thanks in advance for your insight!
Old Apr 1, 2014 | 04:47 PM
Justink201's Avatar
Yes. They probably just put the handle back together wrong. Sounds kind of like what happened to me when I took my door panels off. I didn't pay enough attention to the passenger front door when I put the panel back on and I couldn't get the door open from the inside. Hopefully they didn't break anything though.
Old Apr 1, 2014 | 08:42 PM
bracester's Avatar
Yes they absolutely put something together wrong or broke a few pins and its now putting excess stress on your inside lever, mine finally snapped costing me $900 due to replacement parts and the fact that I could not get my door open from the inside OR the outside. They had to remove the entire door seal to get into my door to open it...took them two days.
Old Apr 1, 2014 | 08:49 PM
wazrun's Avatar
Do you happen to know the size of the rear speaker in the back?
Old Apr 1, 2014 | 09:45 PM
Sorry, no. It should be pretty obvious by now that I know nothing about car audio - or much about cars period, other than what I can understand from reading an owner's manual.
Old Apr 2, 2014 | 07:23 AM
bracester's Avatar
You can double check crutchfield for sizing but I am pretty sure you can fit 6.5s all the way around and espeically in the rears..the fronts you will have to get shallow mounting speakers because of the windows
Yep just confirmed it.
Old Apr 2, 2014 | 10:45 PM
Exclamation Problem solved!
I did nothing! Today, door works just fine! Go figure...
Old Apr 2, 2014 | 11:16 PM
bracester's Avatar
Wild....well good to hear! No pun intended...well maybe
Old Apr 3, 2014 | 12:30 AM
Thanks for a good laugh!
mbergen
Oct 23, 2019 10:26 PM
Daim
Nov 28, 2016 09:28 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
Mike Green
Sep 7, 2015 12:39 AM
philwarner
Sep 3, 2015 10:14 PM
