Speedo
Old Nov 11, 2013 | 11:52 AM
edmorekhumone's Avatar
Default Speedo
Hi everybody
iam after your help i have a jaguar sport 2002 X TYPE , the speedo and the fuel gauge is not working but the Temp and the REV counter is working and its clocking miles, what could be the issue please advise
Old Nov 11, 2013 | 08:49 PM
Thermo's Avatar
Veteran: Navy
Ed, based on what you are describing, you have a problem with the instrument cluster.
Old Nov 12, 2013 | 07:51 AM
Hi Cris is it possible to buy one from the same make and model and swap them over without need to reprogram the car.
Old Nov 12, 2013 | 09:32 AM
billbjork's Avatar
Ed
if your going to pull out the cluster check to see if a tracer on the circuit board is broke that runs to or near the fuel gauge/ speedo. I use a magnifying glass and a strong light You should be able to see if it has cracked or raised off the tracer, sometimes it's just a dark line or a bubble. It might have a coating over it that you have pick at, just take a sharp object ( I used a old dental tool)(asked at the dentist if they had any old ones) or a jewelers file to pick around questionable solder points .
Then if you find one use a fine point soldering iron and just touch it. Look especially by the larger components and ones that could get hot (small step down transformers, resisters) or vibrate loose. They are mass produced by wave soldering and are prone to be under soldered to save a half a penny in production.I know many a TVs that have been tossed for just a bad/ cracked solder joint. OR option2 just get a different one and hope it doesn't have a problem.
Old Nov 13, 2013 | 03:49 PM
Thermo's Avatar
Veteran: Navy
Ed, this seems to be a question here. Some people have been lucky and gotten the instrument cluster to drop right in and all was fine. Others have had to take the vehicle to the dealership to have them reprogram the instrument cluster to make it work. I haven't found a commonality between those that work and those that don't.
Old Nov 14, 2013 | 08:50 AM
Thank you very much I will try first , you are a life saver was really worried about it, if there is anything will let you know
Old Nov 14, 2013 | 01:06 PM
Justink201's Avatar
I was told by my local dealership that they must be programed, and that if I installed the new one and all they had to do was program it, it would cost an hours labor 135 bucks. However, a good friend of mine that works at a good shop said he can use his programmer at their shop to do it for a lot less. I haven't done it yet since I have more important things taking up my money at the moment.
Old Nov 15, 2013 | 12:56 PM
Hi Justin thank you very much for the info where is your friend based. I might want to give it a go.
Old Nov 15, 2013 | 02:51 PM
Justink201's Avatar
Well he is in FL, but I would think that any good shop with the right tool can program it. I can ask him what they use so you can find a shop that uses it too if you want.
RollaJones
Sep 27, 2015 03:31 PM
LnrB
Sep 25, 2015 08:58 AM
carcycle
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
