Sport mode not working?
Old Dec 12, 2009 | 11:05 AM
RickMG's Avatar
Yes, I've had the problem and read here it's very common. The only way I can get it to go on is to press it before I ever take it out of park the first time after starting it. That's pretty much how I get it to turn off too. I can't see any difference driving it in that mode and gas milage is still the same so I just leave it off.
Old Dec 16, 2009 | 10:39 PM
Xrick's Avatar
I have had this problem and what I did was to turn off car..press sport button...turn on car and it came back on. My switch tends to turn itself off when it wants to
Old Dec 18, 2009 | 06:33 PM
MeatBag's Avatar
Default I never had that problem, but...
I leave it in Sport mode all the time - and I hope that isn't a bad thing to do...
I do that because when its off the car randomly wanders between gears constantly (and I have read that complaint in some reviews). I believe Sport Mode causes the upshifts to occur at higher RPMs, which seems to reduce the random gear wandering.
Old Dec 19, 2009 | 10:40 AM
Xrick's Avatar
I leave mine all all the time for the same reason as you meatbag. I received a noitce from jaguar that there is a transmission update recall for the automatics. I have not brought my jag in yet to find out what its about but when i do i will see if what they say about the s switch
Old Dec 29, 2009 | 04:52 PM
85_305's Avatar
I'm curious to know more about this transmission update? What years does it pertain to and how much difference does it make?
Also u guys mention that keeping sport mode engaged helps with gear-searching and rides the rpms out a bit higher? I wonder if this wquld yield in higher gas mileage due to not lugging the motor out with the ridiculously low downshifts?
Old May 30, 2012 | 11:15 AM
Ian D's Avatar
I know this is a really old thread, but I've just had this same problem and I think fixed it. My sport mode button wouldn't work, no light when pressed, kickdown still worked though.
I removed the left carpet panel off the transmission tunnel/centre console and then located a large green connector for the j-gate selector, unplugged it for 5 minutes, re-plugged it and now it's been working for a few weeks now.
Just thought I'd pass this information on here instead of a new thread.
Old May 30, 2012 | 04:03 PM
Ar15fonsi's Avatar
I had the same problem when I bought my car, the only way to enable S mode or disable it, was to press it before I turned on the car.
But It got solved once I replaced my battery, my battery was a little low I guess because my car cranked really low, anyhow my two cents are that when I replaced my battery its now working with no problems like it should, I can turn it on or off while driving or while being parked.
Old May 30, 2012 | 11:01 PM
Carwatcher's Avatar
Had the same problem, I just changed the battery and now it works every time.
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
Sep 3, 2015 12:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
