STEERING WHEEL IS SHAKING
Old Mar 24, 2008 | 12:39 PM
Dennis's Avatar
ud
Default RE: STEERING WHEEL IS SHAKING
Just guessing..but if everything else checks out, it might be a rotor out of balance..Never heard of it myself, but anything is possible.
Old Mar 24, 2008 | 12:44 PM
Cadillac's Avatar
Either warped rotors or you need a Hunter Road Force Balance for your problem
Old Mar 24, 2008 | 01:55 PM
tanboi09us's Avatar
check my thread for shaky steering wheel and see if you find anthing useful in there.
Old Mar 24, 2008 | 03:10 PM
jvegas's Avatar
so are the front different then the back as far as tires go?
Old Mar 24, 2008 | 05:05 PM
jag_genius's Avatar
those contis like to flat spot
Old Mar 25, 2008 | 08:24 PM
ItalianXtype's Avatar
My car did the same exact thing, It took jag 3 months to figure it out butIt turned out that one of my wheels were slightly bent. I was told the sway bar bushings can make the steering wheel shake slightly.
Old Mar 25, 2008 | 08:43 PM
tanboi09us's Avatar
if they are all 205/55/r16 u will be fine, for my case i had three tires with r16 and one with r17.
So the main things you should get it checked out before getting into detailed checkups are:
1. tires: make sure they are in good condition and it is not the source of the problem
2. rims: your rims are not bent
hope this helps
Old Mar 25, 2008 | 09:57 PM
jvegas's Avatar
i have a bent rim and the car shakes just a little around 60. once i hit 70 it feels fine. (If anyone has any 16 or 17 inch oem rims in good shape let me know. come spring time i want to replace them.) can you tell if it is the front or back the the shake is coming from? do you feel it in the arm rest? maybe drive shaft?
Old Mar 27, 2008 | 08:05 AM
Dennis's Avatar
ud
If you think it is the tie rod end..I would get it checked just to be safe..
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
JagLove86
Sep 6, 2015 10:36 PM
