Strange air-conditioner problem
Old May 16, 2009 | 09:19 AM
racerx82's Avatar
You know..i hope someone has a good explanation for this....because when i bought my back then new 2005, the very first day she did what you mention.....never was able to figure it out. I would shut the car off, restart and everything would be fine.....she did that half dozen times in the summer months and dealer could never figure it out as well.....
other then that, she would work fine....
Old May 25, 2009 | 09:25 PM
JohnBurns's Avatar
I am having somewhat the same problem - my 2003 S-type occasionally starts blowing hot air when the air conditioner is on. If I turn the control to the lowest setting (60 degrees), I then get cold air out of the center vent and hot air out of the side vents. I can get the whole system to "reset" if I turn off the engine, wait about 30 seconds, and then restart the engine. The air comes out of all vents cold then. My local Jaguar Dealer inspected it and found low freon. they added, freon, checked the freon for leaks (found none), but this situation of occasional hot air still happens, irregularly. I would really appreciate any solution which others have found to solve the problem.
Old May 26, 2009 | 02:37 AM
Cadillac's Avatar
I assume this problem should be a typical Jaguar problem considering recently I had same issue too ,what's even stranger was I had refilled the R134 according to its specs , it blew off verily cold ,I could not even turn A/C on all the time .
A few days later, it only begun to blow hot air as if there was not enough R134 into the system . Thankfully, that situation lasted only 1 day .
Nowadays, A/C works as it should
Old May 26, 2009 | 07:44 AM
Greenhornet's Avatar
Default A/C
I experienced this once also, after engine was turned off (went into store) and car was started A/C ran fine.
Old May 27, 2009 | 02:20 AM
MeeMo's Avatar
my 2006 x-type have the same problem it give me cold air only when i drive 2 fast
it jast hapend last night
i giss i I have to refilled the R134
Old May 27, 2009 | 11:34 AM
jimmy's Avatar
ud
to all of you that think of refilling....
FIX the leak first .. !!!!!!!!!
Old May 27, 2009 | 05:47 PM
gupdah's Avatar
I had a similar issue when i bought my jaguar, it had turned out that the AC compressor had to be replaced. Only when the RPMs were high or the car was going fast is when cold air would be released. Go to autozone and get a bottle of the CFC(R134 Coolant) and make sure you get the one with the pressure gauge so you can see what you have, When i tested mine, it was in the "dangerous zone" as in too much coolant. IF it says your low, than just fill it up. If worst comes worst, just take back the collant and say you dont need it and that you need to replace the whole compressor. They will understand. Take it to jaguar if you must and they will look at the car for 100 bucks or so and give you their diagnostics.
Old May 28, 2009 | 08:17 PM
canman's Avatar
I would like to check my a/c pressure as you mentioned, where is the low pressure port? On the passenger side against the firewall is two caps, which one is the low port (I would think the bottom one, but not sure). Also is there anything that I should be aware of when testing the pressure? If it turns out to be low, I would like to add the dye to find the leak, it says it is compatible with 134a, so maybe I would just top it up with the dye, if the pressure drops again it should show the leak.... any thoughts on this scenario of testing?
Raul Lara
Sep 14, 2015 07:31 PM
Burdedw
Sep 12, 2015 10:39 AM
simo5555
Sep 9, 2015 06:22 AM
carelm
Sep 5, 2015 01:13 AM
Raul Lara
Sep 2, 2015 05:23 PM
