Struts. ball joints, control arm, help
Old Oct 4, 2014 | 08:00 PM
bostongrun's Avatar
Default Struts. ball joints, control arm, help
If you are having a hard time holding your lower control arm down when you are trying to remove and/or install the lower ball joint. Try this, either use a big vice grip or a large crescent wrench on your lower control arm. Then put a 1 1/2 pipe on the end of the wrench. With the extra leverage you can almost push the control arm to the floor. This will save hours on axle, ball joint, strut and wheel bearing jobs
thedugger1
Oct 16, 2015 10:18 PM
JagBrian
Sep 21, 2015 07:17 PM
ahunt4
Sep 19, 2015 09:49 AM
TreVoRTasmin
Sep 18, 2015 06:57 PM
redgear
Sep 18, 2015 10:05 AM
