Sub Install...
Old Jan 31, 2010 | 09:45 PM
jagFan09's Avatar
Default Sub Install...
Would anyone know a place in the x-types firewall where i could fit my power wire through, i cant seem to find one, pics would be very helpful. By the way its 2gauge.
Old Jan 31, 2010 | 10:56 PM
Jaggyx's Avatar
yes indeed i do, there is a big bunch of wires that are shoved through the firewall. If you look down there with a flashlight you should be able to see them. This is where you shouldnt put the cable through. Now if you look a little towards where the steering column is i believe there is a soft rubber grommet that you should be able to see from the engine compartment and through there on the other side (cabin) there is some foam insulation. I would drill a small hole through the rubber grommet and push the cable through there. Make sure to make the hole smaller so you get a tight fit with the rubber and the cable. The grommet is not an inch or so it is pretty big i would say about 3 to 4 inches. if you cant find it let me know, but a flashlight is a must!
Old Feb 1, 2010 | 04:44 PM
jagFan09's Avatar
Thanks!! I found it but I have one more question, how do i get the wires to the trunk. I have it all the way until i get to the back seats, I just cant find anyway to get them to the trunk, do the back seats fold down?
Old Feb 1, 2010 | 07:12 PM
jagFan09's Avatar
Just found out the 02 models dont have fold down seats but I found a way to get them back there. Thanks anyway!
Old Feb 2, 2010 | 06:52 AM
The Chris X's Avatar
Heh?
My 02 has fold down seats. I folded them down when I was wiring up my sub/amp. Ran the wires under the door sills and then under the back seat plastic cover near the door.
Old Feb 2, 2010 | 12:00 PM
Jaggyx's Avatar
yes all x types should have the fold down seats, 02 models aswell. i remember looking at an 02 before i bought my car and the seats did fold down. For some reason i was messing with everything in the car lol anyways good luck with the rest of your install
Old Feb 2, 2010 | 06:01 PM
jagFan09's Avatar
Really?... Ive looked all around the back seat and couldnt any latch or button anywhere... How do you fold your seats down?
Old Feb 2, 2010 | 09:29 PM
Jaggyx's Avatar
look in the trunk, there should be two circle like latches that you will want to pull. They are in the corners of the trunk by the rear deck. let me know if you need any more help.
Old Feb 4, 2010 | 06:08 PM
Fedekz's Avatar
Hey Jaggyx, Im looking for that very same rubber grommet, is there any chance you could take a picture of this?
maestromaestro
Apr 29, 2013 09:33 PM
teambugsplat
Aug 16, 2012 03:53 PM
Burgurboy
Feb 16, 2011 12:26 PM
HSC
Nov 19, 2009 08:36 PM
