Suspension Noise when i turn
Old Nov 1, 2006 | 03:29 PM
smokinjag's Avatar
Default Suspension Noise when i turn
I have had my 02' Jag for about 2 months now and i've come to notice a creek kind of noise when i turn too fast or hit a dip. Could this be from needing new shocks already, car has 60k miles on it. has anyone run into this problem?
Old Nov 1, 2006 | 09:01 PM
racerx82's Avatar
Default RE: Suspension Noise when i turn
If the sound only happens when making a turn, it could be the driveshafts....(left or right, depand on the turn)
________
BREAKUP ADVICE DICUSSION
Old Nov 5, 2006 | 12:07 AM
aquill1's Avatar
I've noticed that when I make hard turns right or left it makes a sound in my car like the tires are rubbing up against the inside of my wheel wells! I don't think it is possible that it is rubbing because it would show on the tires but I don't know what else it could be. The rims on my car are the same as stock with a size of 225/45ZR17.
Old Nov 5, 2006 | 12:24 PM
racerx82's Avatar
Have you checked the plastic bracket that holds the front sway bar in place? I hear they break easy.....i just don't know what type of noise it would make.......
________
Jeep-Eagle History
Old Nov 17, 2006 | 05:15 PM
X2 Jag's Avatar
I started noticing this squeaking sounds as well....as I make turns or go over speed bumps...its pretty annoying. I have a feeling it might be some rubber bushings on the front suspension...so Racer have a valid thought about checking the front sway bar. Im going to have my Jag buddy at the dealer check it out tomorrow, while he drains and refills my tranny.
Old Nov 18, 2006 | 03:36 PM
racerx82's Avatar
Sounds like yours came loose...which is very unusual...unless you had some work done maybe some accident repair and mechanic didn't bolt it back into place.
________
GENETICALLY MODIFIED FOOD
Old Nov 19, 2006 | 05:34 PM
racerx82's Avatar
The design is cheap, yes, but overall function is very realiable. There is no way in hell your tire can rub on that liner unless you have broken bolts, broken suspension, or your liner was removed for whatever reason, than re-installed incorrectly, and or you have the incorrect tire size/rim.
look over your entire suspention, if you are not sure, get a professional. Front end parts coming off and or rubbing is not something to take lightly.
The liner is held in place by a few screws, and it also interlocks with the fender in case the screws do come out....
It take alot of force to get that liner to move...
I'll be curious as to what you find.
________
LovelyWendie99
Old Dec 1, 2006 | 07:32 PM
racerx82's Avatar
If you hear a squeaking noise when turning most likely culprit is the CVU joint...
Old Dec 2, 2006 | 11:18 PM
aquill1's Avatar
What do cvus cost on this and how hard are they to change?
Old Dec 3, 2006 | 07:33 AM
BuckMR2's Avatar
They cost around £66 and are fitted in under 2 hours like this:-
Old Dec 3, 2006 | 11:15 AM
racerx82's Avatar
Well there ya go....don't get any better...
Old Jan 2, 2007 | 12:57 PM
smokinjag's Avatar
I inspected the area, and the tire is rubbing on the wheel well. Haven't inspected it further, but it started to rub louder recently, any ideas, as far as something being broken, the driveablity is the same as when i got it.
Old Jan 2, 2007 | 02:44 PM
Humy's Avatar
I had a couple squeeks, one time it was the steering rack seal and the other time was the liner. When they fixed the sterring rack seal, they didn't bolt the liner in place right... f'in idiots. All good now though.
Old Jan 2, 2007 | 07:13 PM
BuckMR2's Avatar
ORIGINAL: Humy liner in place right... f'in idiots. All good now though.
USA term..wheel well liner
UK term..sh*t shield
Old Jan 3, 2007 | 01:32 AM
racerx82's Avatar
lol
martybmw
Apr 2, 2016 04:55 AM
02jagstype
Sep 4, 2015 08:20 PM
Harry Dredge
Sep 3, 2015 03:04 AM
innzane
Sep 2, 2015 10:08 AM
