Swap is Complete -- Lincoln LS Engine in My X-type Jag.
Old Jan 25, 2016 | 05:31 PM
  #61
toliy's Avatar
Thank you for your post *****. I have an 04 X-type 3.0, and I'm trying to find an LS engine that's compatible with my x-type. I'm having a hard time finding info out there and was hoping you could tell me what else I should look for, aside from just an LS 3.0 engine? I found some 3.0 LS engines out there, but I'm not finding any cross reference information and was hoping you can help out. Will the LS work for an 04 X-type, and what years?
Old Mar 24, 2016 | 03:26 PM
  #62
Derrick Gasaway's Avatar
Originally Posted by Ojo_Verde
Great job! I plan on doing the same project with my 2000 Jaguar S-Type 4.0 with a Lincoln ls 3.9. From what I've found the swap can be done, I will start the project sometime in the next week or so.
Did u ever finish this
Old Jul 26, 2016 | 09:55 AM
  #63
Keegan Canida's Avatar
im a new member, and very unfamiliar with the similarities between each model of jag. would this exact conversion work on a x-type 03 2.5l??? my engine blew and seized.. and im working with the least amount of cash possible. but if i can do this in my 03.. i get to keep this car
Old Jul 26, 2016 | 01:58 PM
  #64
Alfadude's Avatar
The original poster did it to an '02 2.5 and there was no change to the engines in those years. Hell, they didn't change a whole lot other than the transfer case the entire model run of the cars. So, if you would want to take on what the original poster did, knock yourself out.
There is/was a member on here called Dr. Dome who parted out X-Types. Haven't seen much of him on here the last few months, but you might want to contact him and see if he would have a used engine.
Good luck!
Old Sep 16, 2016 | 11:11 PM
  #65
Thang Nguyen's Avatar
Either remove the engine from top or bottom we still have to remove every things that attach to the engine, but I agree to remove from the top is easier and don't have to deal with front sub frame realignment and jack the front end up so high
Old Sep 26, 2016 | 10:20 PM
  #66
backrow pupil's Avatar
I think I'm in need of a tensioner pulley. ( driver side w/ waterpump). Do you have this?
Old Feb 19, 2018 | 06:30 AM
  #67
Clayton Riddle's Avatar
Default I need information on X-Type 2.5 3.0 engine what will inter chance? It to b
I have a X-Type 2.5 I just purchased it has a blown head gasket here in Kansas City luckily we have a few self service salvage yards and this weekend is 50% decided to go with a 3.0 engine swap my question is does it have to be a Lincoln witch engines have V.A.T I have found a few duratec engine i found a nice Ford 500 low miles its a 06???
does anyone know where I can find a reference guide
Old Feb 19, 2018 | 10:42 PM
  #68
Dell Gailey's Avatar
Just to settle discussion herein about horsepower, and yes if changing from 2.5 to 3.0, changing the ECU will influence performance because of tuning, trims, etc., differences.
Old Feb 19, 2018 | 10:50 PM
  #69
@Clayton =
A more powerful 232 hp version for the 2000-’05 Lincoln LS, Jaguar AJ30 and S-Type, Mazda 6 and MPV, and 2005 Ford Five Hundred, Mercury Montego and Ford Freestyle with direct-acting mechanical bucket tappets.
• A Variable Valve Timing (VVT) with electronic throttle control for the 2003-’06 Lincoln LS, 2003-’06 Jaguar X-Type applications, 2006 Ford Fusion, Mercury Milan and Lincoln Zephyr, and 2009 Ford Escape.
On the 2009 Fusion, a new type of VVT system called “Cam Torque Actuated” (CTA) is used to advance cam timing.
The cam phaser generates its own internal pressure rather than relying on oil pump pressure to move the cams. The result is more advance (47°) and better fuel economy
Old Feb 20, 2018 | 12:34 AM
  #70
willy-k's Avatar
did another same swap last August for a coworker .... did not change ECU's... He's loving it and my pockets loved it tooo
Old Mar 19, 2018 | 04:04 PM
  #71
boringb5's Avatar
I’m about to do this swap with a 05 LS with 54K, does anyone know the torque specs for the cam? Also how is the cam sealed at the end where it sticks out for the water pump? Trying to gather parts before I do this. I bought a head gasket set and lower seal set from felpro. Using all but the head gaskets and valve stem seals.
Old Mar 21, 2018 | 04:03 AM
  #72
why is everyone talking about LS swap why is the Lincoln . I am getting ready to do with me swap this week I just bought a motor out of a 08 Ford Fusion 3.0 with vvt any reson why it wouldn't work question is my car is a manual transmission 2.5 liter I'm going to switch 3.0 is the computer compatible with 3.0 because of that transmission because the obviously going to be out of a vehicle with an automatic transmission
Old Mar 22, 2018 | 07:43 AM
  #73
pab's Avatar
pab
Will any of the sensors be recognized by the Jaguar network and the ECU?
Jaguar: Grace, Pace, and Space - Sir William Lyons
Current: '15 XF (X250) Portfolio AWD 3.0
Past B: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past A: '05 X-Type 3.0/auto Jaguar Racing Green
Old Mar 22, 2018 | 06:11 PM
  #74
Default Why a L's moter
I'm getting ready to do th 2.5-3.0 swap myself
why do Lincoln LS motor there are a ton of 3.0 with Vvt timing Ford Ford Taurus and a few other does anyone know if it has to be in Lincoln and why
Old Apr 11, 2018 | 12:30 AM
  #75
boringb5's Avatar
Help me Obi-wan, How to you guys get this water outlet out of the LS engine? The only way I can see is to remove cylinder head that is covering the bolt. I used blaydes99’s photo to give you guys an idea of what I’m talking about. I need that bolt off to be able to switch the coolant pipe from the Jaguar that is completely different than the Lincoln one.
Thanks!
Old Apr 11, 2018 | 10:05 AM
  #76
boringb5's Avatar
Here are photos of the Lincoln LS pipe that needs to be removed.
Old Apr 11, 2018 | 11:10 PM
  #77
boringb5's Avatar
So, the answer was a 1/4” snap on socket. Then a dremel cutoff wheel, chisel and hammer.
Old Apr 12, 2018 | 12:50 PM
  #78
Patterson's Avatar
Appetite for destruction, Lol. That low profile Snap On swivel looks pretty handy. I've had the upper and lower manifolds off my car for a couple days to R&R the coil packs and plugs, and I found the knock sensor down there, but couldn't get it out to replace it bc of that elbow that runs over the top of it. The one you are swapping over to the LS motor. The flange having two bolts, one you can see, and the other that looks about impossible to get to. I didn't want to drain the coolant and get into tearing apart that steel water line from the water pump to the engine, so I left the old knock sensor in place and cut the harness off. Then I installed the new KS about 6" away from the old one. Was able to do this bc there is a bolt there that appears to hold a cover plate on the block. Anyway, a little off topic to what you're doing, but wanted to chime in. I didn't think of it, found this tip on the forums.
Old Apr 17, 2018 | 10:18 AM
  #79
boringb5's Avatar
So, I take it that I should replace the knock sensor while it’s out? I’ve seen a few posts about bad knock sensors and now that you bring it up this would be the time to swap it. Also does anyone know if I can leave the a/c system intact and remove the engine? My a/c is fully charged. Don’t want to vent to atmosphere...
D.K
Dec 10, 2023 02:05 AM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
