Swapping Out Transfer Cases
Old Nov 16, 2023 | 06:26 PM
Car lover's Avatar
Default Swapping Out Transfer Cases
I currently have a 2005 x type sport with dsc and need to get a new transfer case my question is can I install a 02/03 transfer case with the viscous coupling without interferring with the dsc system as my transfer case now is non-viscous(open) or will that present problems?
Old Nov 17, 2023 | 11:17 AM
Dell Gailey's Avatar
SEARCH IS A MARVELOUS TOOL
https://www.jaguarforums.com/forum/x...button-104930/
Old Nov 17, 2023 | 11:56 AM
Car lover's Avatar
Dell I appreciate the response but I have read the entire forum and maybe I missed it but it just talks about the dsc system and the transfer case nothing about using an ealier style transfer case in post 04 models.
Old Nov 17, 2023 | 03:39 PM
It actually DOES talk about a pre 2004.25 HAVING DSC, so reading the link, particularly "Thermo's" comments on DSC being part of the BRAKING system it would seem to me at least that it would have little to do with whether the X has or doesn't have the Vicious type transfer case.
And Astromorg's link explains VC and comments on VC vs non VC equipped cars with DSC.
Old Nov 17, 2023 | 06:02 PM
Car lover's Avatar
Dell so if I am reading the forum right and understanding you correctly I can install an 02/03 transfer case with viscous coupling on a 05 x type that came stock with a non viscous transfer case. Sorry for the confusion on my end I just can’t find a straight answer I understand the dsc is controlled by the brakes but I just wanted to make sure that the dsc would still work the exact same as it does with a non viscous transfer case as it does with a viscous one.
Old Nov 17, 2023 | 06:22 PM
Thermo's Avatar
Veteran: Navy
Car, it should work. The sensors should be the same and the bolt patterns are the same. So, should not be a big issue. Read up on pulling the front half shafts. Easy thing to do, but, also very easy to do it wrong and now you are diving into the transmission.
Old Nov 17, 2023 | 06:39 PM
Car lover's Avatar
Thanks Thermo, and thanks for the heads up I know not to move the shaft more than 200mm
Old Nov 17, 2023 | 07:19 PM
Car lover's Avatar
Thermo, have to drain atf before removing the transfer case as it will leak? Before I joined this forum I saw u in so many posts thanks for spreading knowledge!
Old Nov 18, 2023 | 05:04 AM
Blues boy's Avatar
Car lover,
We swapped out worn transfer case in my 2005 X type which was a non viscous type to a low mileage 2002 viscous coupled one with no issues.
Drives superbly
Joshua skinner
Feb 3, 2018 07:25 AM
Rayjag
General Tech Help
Oct 16, 2016 07:17 PM
Jagtype
Aug 7, 2014 08:42 AM
geoffbp58
Nov 24, 2013 11:12 AM
Thermo
Feb 19, 2009 08:08 PM
